Drive Sfaft join replacement
Old Jan 26, 2009 | 09:22 PM
RubberDuck's Avatar
RubberDuck
Glad you got it going man.
Old Jan 27, 2009 | 06:56 AM
Neal 97 250's Avatar
Neal 97 250
Cody Reps sent, John too. Thanks for taking the time to spell this out. Cody that took some time to write it up. this is why this place rules!
Old Jan 27, 2009 | 07:34 AM
RubberDuck's Avatar
RubberDuck
Thank you Neal.
Old Jan 27, 2009 | 08:26 AM
CampSpringsJohn's Avatar
CampSpringsJohn
Thanks, Neal. I appreciate it.
Old Jan 27, 2009 | 08:35 AM
Action4478's Avatar
Action4478
Tried to rep ya Cody ,,gotta spread it around yet ...
Old Jan 27, 2009 | 08:39 AM
RubberDuck's Avatar
RubberDuck
Thanks Rick, but don't forget about John.
Old Jun 5, 2011 | 08:34 PM
Brian Straz's Avatar
Brian Straz
Ive spent some time searching today about slip joints and I can tell you know more than a little. I have a pretty simple question for you. I greased my slip joint today and have successfully got rid of the take off clunk. However I now have a vibration that starts at 55 and levels off around 65 or 70. I just replaced the back tires before I greased it should I have them rebalanced. Could I have missed a spline or 2 while lining up the shaft? I'm lost as to why this has popped its head up. Any help is greatly appreciated!!
Brian 2002 7.3 CC SD 110k
Old Jun 5, 2011 | 09:29 PM
CampSpringsJohn
It is possible that the driveshaft is off a spline or two. In a nutshell, just make sure the universal joints are in line with each other. In other words, make sure that the u-joints are all turned the same way. All the cups should be in a line. It is possible that the back portion of the driveshaft could be off 180 degrees. When the driveshaft is balanced, the 2 pieces were put together at the slip yolk a certain way. It is quite possible that the u-joints could be in line but that you have the shaft installed 180 degrees from the balance point. Now, having said that, after checking the allignment of the u-joints, I would check the tires next.
Old Jun 6, 2011 | 02:49 AM
joe_13894's Avatar
joe_13894
Originally Posted by CampSpringsJohn
By the way, the u-joint at the tranny should be held in place with straps too. Install new straps there as well if you go that route.
The transmission yoke on mine does not have straps. It is a snap ring yoke. The yoke just slips out of the transmission to pull it from the truck.
Old Jun 6, 2011 | 09:12 PM
CampSpringsJohn
The you don't have to worry about making sure the u-joints are lined up. Unless they were messes up when the driveshaft was made!
propellerhead
15
Apr 25, 2017 12:28 PM
gomfrddy
Dec 12, 2012 01:33 PM
gomfrddy
Mar 9, 2012 10:28 AM
gomfrddy
Dec 21, 2011 12:47 PM
gomfrddy
Jan 23, 2007 01:43 PM
