?Line Pr. PSI?
Old Jan 22, 2009 | 04:06 PM
cowmilker08's Avatar
cowmilker08
Question ?Line Pr. PSI?
i've heard alot about the fpr mod and how and when to do it. so i was wondering if my edge evolution programmer would tell me what the current pressure is.
i plugged it in and went to the data stream option. it gives the current rpms, engine oil temp, transd fluid temp, exhaust back pressure, and line pr. PSI. i don't know if this refers to the the fuel pressure. does anyone know.
anyway cruising at 70mph the reading for this was around 30 and with the petal to the metal it reached 71 at the highest point.
on another note the exhuast back pressure never got over 28 psi. is this good?
any input would be good.
Phil
Old Jan 22, 2009 | 04:33 PM
tjbeggs's Avatar
tjbeggs
The line pressure you are seeing is for the transmission not fuel pressure. The PCM doesn't measure Fuel pressure.
Old Jan 22, 2009 | 04:36 PM
cowmilker08
it always seems to me that when noone else knows an answer to my Qs you do. so how do i check the fuel pressure?
Old Jan 22, 2009 | 04:44 PM
tjbeggs's Avatar
tjbeggs
There is a schrader valve on the side of the filter housing. Use a fuel pressure gauge (tire gauge will work poorly in a pinch)
Old Jan 22, 2009 | 04:53 PM
cowmilker08
does the key just need to be on or the engine?
Old Jan 22, 2009 | 05:33 PM
live2wheel's Avatar
live2wheel
engine needs to be running to check fuel pressure.
i have a '97 and my truck did not come with a exhaust back pressure sensor . it must be aftermarket. califorinia model maybe?
Old Jan 22, 2009 | 05:53 PM
c00nhunterjoe's Avatar
c00nhunterjoe
it should have the sensor, its in one of 2 locations, the first is the way tj's shows and the other is center of motor on top of the water pump.
Old Jan 23, 2009 | 06:39 AM
tjbeggs's Avatar
tjbeggs
oh yeah sorry. You need to have the engine cranking or running., and Joe is right. two possible locations for the EBP sensor on the 97. Mine is the in the early 97 location.
Old Jan 23, 2009 | 08:31 AM
Neal 97 250's Avatar
Neal 97 250
Agreed. Mine is in the center and just in front of the HPO reservoir.
I recently had to replace my steel hose for the BP sensor. Look in my pics in my sig for more info. It took several attempts to get the hose for the late '97's. they only used it 1/2 year.
Old Apr 29, 2009 | 11:44 AM
wildstang's Avatar
wildstang
VT Chapter Ldr
Got a question on the fuel pressure check, is it better to hook the gauge up to it then start or when already running or does it matter?
Also I have used my gauge on a gas engine, is it ok to use on the diesel also?
Last question, for now anyways, can someone direct me to a good post with directions and maybe pictures of the fpr bb mod? Thanks for any help.
Old Apr 29, 2009 | 11:56 AM
Hussler's Avatar
Hussler
This should get you going ... https://www.ford-trucks.com/forums/6...-shim-mod.html
66v8baby
Ford Truck Parts for Sale
Apr 22, 2017 09:05 AM
Faster71
30
Nov 1, 2016 12:54 PM
krazy_horse
WTB - Parts & other
Oct 18, 2015 04:26 PM
psquare7575
16
Aug 9, 2015 09:58 AM
'94Nichols
1978 - 1996 Big Bronco
Sep 11, 2007 04:35 PM
