I did the 10k mod today and definitely notice more bottom end. Couldn't find anything b/w 10 and 22 so tried 22k and truck didn't like it. Started cutting out not long after I got after it. Do these resistors go out? Do you guys carry a spare?
The resistor shouldn't go out... but the way I have it set up is one male end and one female end so if something should happen to it I can just plug the stock wire back together.
To get the 14.7k and 15.6k and 20k you just use two resistors inline with each other.
I found that the 14.7k and 20k worked best on mine, but it just depends on the truck.
That is how I wired mine too so I don't know why I asked about carrying a spare. I didn't know about putting them in line to get the others. I might try one of them sometime but for now I was happy with the 10k. Thanks
