Turbo Light
Old Jan 20, 2009 | 11:12 PM
  #61
Tenn01PSD350's Avatar
Tenn01PSD350
You don't need to buy a manual. Most of us have one if you cannot download one for free. You just need to be specific. We have all but torn down and rebuilt engines here, and I believe we could pull that off too.
Old Jan 20, 2009 | 11:19 PM
  #62
cangim's Avatar
cangim
Well that sums the light question for me. It is the check engine light. You should get the codes read, then you will for sure know what is going on. In the link you should be able to down load a PDF version of the manual for free. No sense in buying one for the once in a blue moon you look at it.
Old Jan 20, 2009 | 11:29 PM
  #63
Tenn01PSD350
I don't recall where you are at. You might have someone close by that can scan that rascal for free. That is worth a ton of money in case you don't realize it. A competent fella can tell volumes about your truck.
Old Jan 20, 2009 | 11:30 PM
  #64
bigenough's Avatar
bigenough
ok thanks im sure i will be on later to bugg you guys more thanks alot
Old Jan 20, 2009 | 11:31 PM
  #65
bigenough's Avatar
bigenough
im located in Abilene TX
Old Jan 20, 2009 | 11:35 PM
  #66
bigenough's Avatar
bigenough
One other ? does any one sell an oil pan gasket for my truck i cant find one any where?
Old Jan 20, 2009 | 11:57 PM
  #67
Tenn01PSD350
Yes, they do, it's called RTV. I have no link right now, and doubt that is leaking. Wait for one of the TX guys to get up with you. I have a hard time believing your pan is leaking as opposed to a rear main seal which also almost never leaks.
If you are convinced you have a pan leak, there is a procedure for that. I can post it up, but not tonight. No gasket there.
Old Jan 21, 2009 | 04:21 PM
  #68
bigenough's Avatar
bigenough
Ok thanks I replaced the rear main seal less than six months ago. I know there is rtv I was wanting a real gasket, the motor is ready to be pulled im just waiting for the weedend to get some help, cant do it by myself im a single parent of two boys 3yrs and an 8mth old living off E-4 pay so cant afford to fix my truck and a sitter.
Old Jan 21, 2009 | 04:22 PM
  #69
bigenough's Avatar
bigenough
So with that being said we will see what the hell is leaking for sure.
Old Jan 21, 2009 | 05:22 PM
  #70
Tenn01PSD350
That is one way to do it. Good luck. I know what you mean about the E4 pay. Only thing good about that was that it paid better than the three grades I went through to get there.
Old Jan 21, 2009 | 06:43 PM
  #71
bigenough's Avatar
bigenough
Well i had already pulled everything so its to late now no need to stop at this point.
Old Jan 21, 2009 | 07:28 PM
  #72
Tenn01PSD350
That's cool, I don't have a problem with it, not that it should matter to you anyway. It is your truck. Do you have the info to reseal the pan?
Old Jan 21, 2009 | 07:32 PM
  #73
boone1965's Avatar
boone1965
if you can take a picture of teh "turbo" light youare talking about and post it so we can look. I havent seen one either. This is new.
Old Jan 21, 2009 | 07:34 PM
  #74
bigenough's Avatar
bigenough
Well I ordered a new pan but I have yet to find a gasket for it, but while I have it out I was gonna buy a rebuild kit for my fuel injectors to give me more fuel, so far I have only found one type of kit any ideas, also gonna replace the glow plugs it wont start if its below fifty without plugging it in, and also i was thinking about replacing the turbo wheel while its all out.
Old Jan 21, 2009 | 07:35 PM
  #75
bigenough's Avatar
bigenough
well my truck is all apart right now but I can try and find a pic in a manual or something.
