Turbo Light
Old Jan 20, 2009 | 08:23 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Did you pull the engine to do this, how did you take the pan off?
Old Jan 20, 2009 | 08:25 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
Does my truck have a turbo light? BTW it's a 2002.
Old Jan 20, 2009 | 08:29 PM
CSIPSD's Avatar
CSIPSD
Originally Posted by bigenough
A light in the dash had came on and I asked some one what it was and they said its the turbo light, this is the first diesel i have ever owned so not on top of everything yet thats why im on here.
YouTube - 54% duty cycle
At the end of this video, is that the light you are seeing? Called the SES light or on the OBS trucks (95-97) a CEL...
If so I would bet its from ICP (injector control pressure) or Overboost. Chip or programer?
I have a 2003 7.3, i can see it leaking, I tried resealing it but no luck
2003 f-350 7.3 Lariat qaud cab short wheel base 8in lift sittin on 38in open country m/t
well put it this way and no offense to any one, i drained the oil to try and reseal the pan, when i got done i put the new oil in and before i even started the engine it was leaking and yes from the pan right where it dips around the crankshaft.
well the first time with just sealer (gasket maker) that didnt work so i cut a gasket out of cork gasket maker along with more sealer
If it is the oil pan (and it could be) the only way to fix it is to pull the motor, turn it over and clean everything very well, let it dry and then install a new gasket.
Old Jan 20, 2009 | 08:31 PM
Tenn01PSD350's Avatar
Tenn01PSD350
I believe yours comes with a 500w plus bulb Kris.
Old Jan 20, 2009 | 08:32 PM
CSIPSD's Avatar
CSIPSD
Gezz, cut the guy some slack. He is newbe
Old Jan 20, 2009 | 08:34 PM
bigenough's Avatar
bigenough
all Stock but i just dropped the tranny to replace the fly wheel which had broke aound the bolts, when i pulled the tranny i didnt have to unbolt the torque converter from the fly wheel b/c there was nothing holding the fly wheel to the engine any longer, it has 160,000 on it i also have already pulled everything prior to pulling the engine
Old Jan 20, 2009 | 08:35 PM
Tenn01PSD350
I hear you, these are what I refer to as sidebars, though probably inappropriate.
bigenough's Avatar
bigenough
ok with that being said there is a slight fuel leak behind the fuel filter assembly
Old Jan 20, 2009 | 08:37 PM
Izzy351's Avatar
Izzy351
That's likely to be the fuel drain O-rings. Easy fix.
Old Jan 20, 2009 | 08:39 PM
miller_feed
Have a look at this, if it is what Joe said, this should help you. click here
bigenough's Avatar
bigenough
would that be my problem if im not gettin good fuel pressure
Old Jan 20, 2009 | 08:42 PM
Tenn01PSD350
How bad is this leak? Drips down steady until below normal fill or what?
Old Jan 20, 2009 | 08:43 PM
  #28
CSIPSD's Avatar
CSIPSD
What he said. A couple O rings and its fixed. One way to avoid it again is to cycle the drain every time you open the hood.
  #29
Tenn01PSD350
Oh yeah. Have you tested the pressure reading?
  #30
bigenough's Avatar
bigenough
that is correct miller and joe,
