2005 powerstroke wont start need help please
Old Jan 15, 2009 | 09:27 PM
clay's Avatar
clay
the truck has new headgaskets,egr cooler,hpop,ipr,icp in the last 2,000 miles ago and the steering wheel controls would some times work so today i took the cover off the bottom of the steering wheel to check for wires the the truck seemed like it shudderd and died and now it will not crank back up checked all fuses and wire seem all ok what could it be a bad ipr the truck has no codes at all tach moves while cranking oh yea it is a stock truck
Old Jan 15, 2009 | 09:45 PM
liv's Avatar
liv
So it started before you took the steering wheel off?
Old Jan 16, 2009 | 06:48 AM
clay's Avatar
clay
yes it did
Old Jan 16, 2009 | 08:07 AM
Kep4's Avatar
Kep4
Jäger
Did you check for codes? Maybe the PCM crapped out, unless the STC fitting just suddenly came apart. Any hard start issues recently when it was warmed up? Does the oil psi come up when cranking? When did you last change the fuel filters?
If the truck is under 100K in mileage then it's time to have it hauled to a Ford Service Dept. with Certified 6.0 Techs for diagnosis/repair.
Old Jan 16, 2009 | 09:18 AM
6LPSD's Avatar
6LPSD
this is a start, check the wiring under the steering wheel again make shure nothing is loose. next do you have a good code reader? if so try and scan for codes, if it a stc fittting issue the truck may need towed to a reputable 6.0 diesel tech.
Old Jan 16, 2009 | 09:22 AM
BPofMD's Avatar
BPofMD
Veteran: Navy
I know that if you turned the steering wheel too far on removal or replacing, you can break the clockspring wires! What I do NOT know is is any broken clockspring wiring will effect startup.....
Old Jan 16, 2009 | 09:32 AM
Wyatt66f100's Avatar
Wyatt66f100
Clockspring wires breaking only effects air bag operation and horn operation.
Sounds like a call back i'd take it back to the last guy that worked on it and ask him if he put all new o-rings in the high pressure fuel system. If he didn't a high pressure oil leak can occur causeing hard start long crank conditions. there are a lot of hacks out there.
-6.0L diesel tech
Old Jan 16, 2009 | 09:47 AM
clay's Avatar
clay
ok i got some codes b1352,u1900,b1318,b1360,p0098 no the truck was running really good and i didnt take the steering wheel of just the black cover under the steering wheel sorry about that had no problem starting in the morning and when i turn the move the steering wheel the lights for the buttons will come on and then if i move it again it will go off idk whats wrong thanks for the help guys oh yea and the horn does not work either
Old Jan 16, 2009 | 10:09 AM
6LPSD's Avatar
6LPSD
TRY THESE OUT
B1352 Ignition Key-In Circuit Failure
U1900 Can Communication Bus Fault
B1318 Battery voltage Low
B1360 Ignition Switch circuit open
P0098 Intake Air Temperature Sensor 2 Circuit High
type any other codes you have at the below site.
Diagnostic Trouble Codes (DTC)
Old Jan 16, 2009 | 03:32 PM
clay's Avatar
clay
what could it be thanks
Old Jan 16, 2009 | 04:50 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
B1352 and 1360 are both ignition related.....I'd be looking for unattached/broken wires where you worked in the column....
Old Jan 17, 2009 | 05:50 PM
cparks's Avatar
cparks
Sounds like it might be that the truck is not sensing the key being in the ignition. From doing some Remote Start systems on trucks I know some have a sensor for this that it must read the chip in the key to start. The ones I have worked on have very small fine wires leading up to the ignition "key" area behind the steering wheel itself. For the heck of it if you have another key try that other key and/or wiggle the shifter if an automatic while trying to start it.
Old Jan 17, 2009 | 05:58 PM
liv's Avatar
liv
Might want to check your batteries too
If the voltage is too low your trucks not going to start. She needs every bit of power. That would be why your gauges are fluttering also. Also possibly why you were having issues with the steering wheel controls.
Old Mar 21, 2012 | 10:02 AM
greentree ford's Avatar
greentree ford
f350 wont crank
2005 f350 with 6.0 wont crank lights wipers radio all work batteries checked there ok. Ran fine yesterday this morning it cranked once then went dead now no crank at all
Solvaysam
Jul 31, 2017 05:30 PM
HoosierBinCo
Jul 2, 2017 10:13 AM
duck fan
Jun 26, 2017 10:35 PM
Goose84
May 9, 2017 04:55 PM
Firefighter209
Sep 4, 2015 01:14 PM
