Galvanized patch panels!!!!!
Old Jan 15, 2009 | 08:49 PM
78f250lj's Avatar
78f250lj
Great source for patch panels...made in the USA...nice, thick, straight galvanized pieces......these are very inexpensive!
Table of Contents
The website is http://www.tabcobodyparts.com/
I have used the cab corners, floor pans, and door pillars.....I can't say enough good things about these patch panels.
Sorry for the rant but I just found my old catalog while cleaning up my room.
Old Jan 15, 2009 | 09:29 PM
tatonka04's Avatar
tatonka04
I second that. I used one of there cab corners on mine and can't complain. Especially not the price.
Old Jan 16, 2009 | 12:38 AM
bmuhlbach's Avatar
bmuhlbach
i got my Mustang parts there good stuff and great prices.
Old Jan 19, 2009 | 05:43 PM
BarryMc's Avatar
BarryMc
Just a small safety note. If the metal is galvanized you should remove the coating prior to welding as the fumes are dangerous, grinding or sanding should be done with a dust mask or particle respirator.
I think I'll try some of their panels, sounds like they're pretty good.
Old Jan 20, 2009 | 12:01 PM
66f1004x4's Avatar
66f1004x4
yeah they dont sound too bad! might get some cab corners for my truck!
Old Jan 23, 2009 | 11:36 AM
Chaosracing's Avatar
Chaosracing
Like mentioned above, before welding or adhesive bonding the metal to the body, the area must be ground down to remove the coating. So even though you bought a galvanized part, the places where you weld or adhesively bond will no longer be galvanized. To weld you can use weld thru primer. But no matter what, you must protect the metal after installing to prevent future rust issues. I never install galv patch panels and never will.
HuntinBronc
30
May 8, 2022 11:07 PM
newguy399
Oct 10, 2016 02:38 PM
gabescanlon
May 8, 2015 09:51 PM
Mikey_23_ny1
Apr 26, 2015 07:35 PM
jmadsen
Nov 4, 2008 11:31 AM
