Cold Weather No Start
Old Jan 15, 2009 | 06:52 PM
Welk49's Avatar
Welk49
Well I haven't needed my truck in a couple of days, have started it everyday and let it warm up. The truck has been plugged in. Tried going out and starting it tonight and no start. The first time I cranked it over it started up and ran for 30 sec. then died. Now all it does is turn over, but will not start. Just replaced all glow plugs and relay and checked them out and they're working fine. Could I have gelled fuel? The fuel was a winter blend, and I had put some Power Service in it when I fueled it up last week. Thanks for any ideas. It has been frigid here the last couple of days and right now it's
-13 and that's without any windchill. Supposed to be in the -20's tonight so I'd like to get it started.
Old Jan 15, 2009 | 07:19 PM
F-350PSD's Avatar
F-350PSD
sounds gelled, maybe some diesel 911 in the fuel filter?
Old Jan 15, 2009 | 07:30 PM
c00nhunterjoe's Avatar
c00nhunterjoe
sounds liek a gel issue, wont be glow plugs since it fired up and ran for 30 seconds. remove the filter cover and see what the bowl looks like. my guess is the fuel heater worked on the bowl and it ran until the hot fuel was gone.
Old Jan 15, 2009 | 07:31 PM
Welk49's Avatar
Welk49
just replaced the fuel filter had new one in the garage. The old one didn't have any signs of gelling, the fuel in the bowl looked good. I am still going to get some 911 and try it. But it wont be until tomorrow when I can get that. Man this pisses me off Does the fuel heater work when the key is on only? Or does that work when the block heater is plugged in?
Old Jan 15, 2009 | 07:32 PM
c00nhunterjoe
any tailpipe smoke when cranking for a while?
Old Jan 15, 2009 | 07:37 PM
Welk49's Avatar
Welk49
haven't seen any, my wife is pregnant and due in a month so I don't want her out here in the cold watching my tail pipe or in the truck cranking. I think I'm going to have my dad bring over a tube heater tomorrow and set in front of it, then have him give me hand.
Old Jan 15, 2009 | 07:51 PM
Welk49's Avatar
Welk49
had neighbor check tailpipe there was no smoke coming out at all. I am giving up tonight I don't want to burn the starter up.
Old Jan 15, 2009 | 07:53 PM
c00nhunterjoe
no smoke means no fuel, either gelled up or have no injectors firing
Old Jan 15, 2009 | 07:57 PM
FARM69's Avatar
FARM69
Yep, get a bottle of 911 and let it do its magic. That stuff really works wonders on a gelled system.
Old Jan 15, 2009 | 07:59 PM
Welk49's Avatar
Welk49
thanks for all the help going to try the 911 and see what happens will let you know what happens
Old Jan 16, 2009 | 06:44 AM
stephen.south's Avatar
stephen.south
Quick question. I'm running 15w-40 with Lucas oil stab. So my oil is thick. When cold would this prevent injectors from opening?
Old Jan 16, 2009 | 01:22 PM
jimwilsonmasonry's Avatar
jimwilsonmasonry
i dont think were supposed to run lucas oil in our engines it foams up in high rpms and is bad on our hpop
Old Jan 16, 2009 | 04:45 PM
Welk49's Avatar
Welk49
yeah that's is what I had read as well, my buddy runs it and has never had any problems knock on wood
Old Jan 17, 2009 | 08:35 AM
FARM69's Avatar
FARM69
To answer your question Stephen, Yes, the injectors would have some difficulty at first firing the injectors because the oil is thicker than molases. If your performing a lot of extreme cold starts I recommend switching to a syn 5-30. You'll notice a night and day difference with your cold starts.
Change your oil and get that Lucas out of there. It's not recommended for HEUI injector systems.
jed1894
23
Sep 13, 2016 07:42 AM
chuck641
3.8 & 4.2L V6
23
Mar 10, 2016 12:16 AM
k_conner
21
Apr 24, 2009 02:22 PM
Pilgrim
Dec 12, 2005 10:37 PM
killerklown
1978 - 1996 Big Bronco
May 18, 2004 06:50 AM
