1978 - 1996 Big Bronco
Bronco fuel pump nightmare
Old May 17, 2004 | 10:55 PM
killerklown's Avatar
killerklown
Hey,
My fuel pump grew louder and louder, then one day it died. I forked out the $150 for the new one, and after plenty of frustration got it in. It works fine and was quiet as could be. Just now tonight I decided to make a late run the the store, and as I turned the key, I heard the familiar weeeee-uuuuuu of the fuel pump starting up. This sound had disappeared when the new pump was put in. So I walked behind the truck and can hear the pump running again, not as loud as when the old one failed, maybe 50%, but thats how it started last time.
Should I be freaking out here or what???? There's no way I'll be sleeping tonight. Let me know what you think, or have experienced.
thanks
Old May 17, 2004 | 10:56 PM
mustangman65_79's Avatar
mustangman65_79
in tank or on the rail?
Old May 17, 2004 | 11:11 PM
killerklown
its in the tank, '95 full size Eddie Bauer 351w
Old May 17, 2004 | 11:12 PM
mustangman65_79
When u changed pumps, did u clean off the little foot thing on the fuel pickup arm?
Old May 17, 2004 | 11:16 PM
justshootme84's Avatar
justshootme84
It's normal for the pumps to make noise, some are just louder than others. Remember to keep at least 1/4 tank of gas and not run it empty, which will overwork the pump.
Old May 18, 2004 | 12:58 AM
Swit's Avatar
Swit
as an addendum to Justshootme84: the level of fuel also tends to muffle the pump noise.. some. YMMV
Swit
'94 XLT 5.8
Old May 18, 2004 | 06:50 AM
ALSAIR's Avatar
ALSAIR
Another little suggestion. Locate the fuel pump relay and check the terminals for any signs of corrosion. A poor connection due to corrosion could cause the motor to pull higher amps, run a little harder and warmer, and shorten the life of the pump.
She Ain't Revved Ti'll The Rods Are Thrown!
Al
66ca
52
Apr 15, 2012 04:43 PM
86FUZZY
Sep 15, 2008 04:25 PM
3xtrastout
Nov 15, 2005 07:57 AM
CodaSmog
Feb 20, 2004 08:12 PM
pdinella
20
Jul 8, 2002 07:18 PM
