sorry i DID NOT know this was english class........anyway i put a new cole hersee relay on when the truck was already warm and did not need the glow plugs....so when i put all the wires on why were the 2 small post hott??i thought only one got hott and thats what opens it??
Didn't you get the memo?
One of the wires that go to a little post is hooked to the PCM. When the conditions are right, the PCM sends a ground signal through that wire to activate the GPR. Once the GPR goes off, the wire shows hot again. You can play with a volt meter and watch to see how it all works. Glad to hear the screwdriver trick worked for you. And yes, a little punctuation does make things easier to read.
Hang around. There's lots of good info available here.
