p0344 Code
Old Jan 14, 2009 | 06:43 PM
  #31
Hussler's Avatar
Hussler
How long does the "wait to start light" come on? At around 50 degrees I would think .. best guess would be maybe 4 seconds. If much longer then you might have a bad oil temp sensor.
Old Jan 14, 2009 | 06:49 PM
  #32
c00nhunterjoe's Avatar
c00nhunterjoe
even at 50 degrees the glow plugs will come on longer. and turning the key off then back on will just start the process over, the pcm doesnt care how hot the plugs are, it cant tell, all it sees when you turn the key back on is that the oil is 50 degrees so it sets the ontime accordingly
Old Jan 14, 2009 | 06:57 PM
  #33
Hussler's Avatar
Hussler
True .. however I asked the question how long the "wait to start" light was on as that is a true indication what the PCM thinks the oil temp is. If he comes back and indicates the "wst" light is on for 10 seconds at 55F then there is another issue.
Old Jan 14, 2009 | 06:59 PM
  #34
c00nhunterjoe
simple check is unplug the eot sensor and try it but i cant see the eot causing this large of a concern
Old Jan 14, 2009 | 07:26 PM
  #35
97biostroke's Avatar
97biostroke
Ok i think the wts light is not a concern i thought it would shut off it the plugs were already hot but i was wrong. Main concern is will the glow plugs cause the problems i've been having? Or am i testing the harness the correct way? I also picked up another spare CPS i'm gonna put on when i get the time, just in case i put a bad one in ( i know its not likely but worth a shot ).
Old Jan 15, 2009 | 07:52 PM
  #36
97biostroke
OK i checked the resistance of the fourth harness and got a reading of 93 ohms on the outside pin. Is that just a bad glow plug? Or would that be causing all my problems?
wiwillis1980
Jun 24, 2014 11:02 PM
rch10007
Electrical Systems/Wiring
13
Oct 26, 2013 10:05 PM
jrvance7
Modular V8 (4.6L, 5.4L)
Jul 27, 2011 05:13 PM
kennyruetsch
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Dec 11, 2006 05:14 PM
79CEEJAY
Feb 15, 2004 10:51 AM
