Heater Core!!!
Old Jan 12, 2009 | 01:35 PM
lurchy98's Avatar
lurchy98
Heater Core!!!
Hello everyone,
I need some help replacing the heater core on my 98 2.5 ranger. I have done a search but can't find much detailed information on how to replace it. Any help would be greatly appreciated.
Thanks!
Old Jan 12, 2009 | 03:55 PM
matt's2.9STX's Avatar
matt's2.9STX
On Rangers, it's really easy. Just make sure the cooling system is clean & flows well afterward. If not, get it flushed. To start, remove the clamps of the heater hoses & slip them off. Replace hoses if any wear on them while you're at it - with new clamps. Pull the black interior clips from the carpeted cover under the right underside of the dash & pull the core back & down. Reverse that procedure & you're done.
Old Jan 12, 2009 | 08:09 PM
Thoth88's Avatar
Thoth88
It also helps to open/remove the glove box, gives you more visibility of the core. Did on my '94 atleast.
Old Jan 12, 2009 | 08:41 PM
drb1956's Avatar
drb1956
I certainly must have written a few dozen posts extolling the merits of a Chiltons manual-soooooo much info for so little!! Check in to getting one-not that expensive when you think about the amount of info you WILL have, and to find out about things you didn't know about your Ranger..It will take you step by step on how to make this repair, and many others.....
Old Jan 13, 2009 | 12:30 AM
matt's2.9STX
I'll generally agree about that. It has its flaws & missing bits, but it IS worth the price. I finally found a copy locally at the closest Murray's for '91-99 in the shrink wrap no less. Paid $20.
Old Jan 13, 2009 | 10:05 AM
Bear River's Avatar
Bear River
Former ******
I would agree, as nice as this forum is, you still can't beat having a good service manual. Sure the illustrations are sometimes wrong, but they contain specs, and the complete procedures and everything. I have both a Haynes and a Chiltons for all my vehicles.
Old Jan 13, 2009 | 11:14 AM
5.0B2's Avatar
5.0B2
You can quite often find factory Service manuals in good condition on eBay also
Old Jan 13, 2009 | 02:22 PM
Rockledge's Avatar
Rockledge
Unfortunately for the OP, his is a '98, and so when it comes to heater core replacement, that's going to be a fairly tedious repair. That's because on '95+ Rangers the dash must be removed (or at least pulled back far enough) in order to gain access to the core. There is no easy access panel like on the earlier Ranger models.
There are some good instructions on how to pull a '95+ dash in PSKSAM2's post here:
https://www.ford-trucks.com/forums/s...57&postcount=4
Old Jan 13, 2009 | 04:59 PM
lurchy98's Avatar
lurchy98
Thanks for your help guys! This is going to be a BIG job but will have to be done. Luckily I have a second vehicle.
HMAN1055
13
Dec 15, 2014 11:44 AM
FordGurl83
Modular V8 (4.6L, 5.4L)
Nov 3, 2014 06:54 AM
PHI
Oct 28, 2007 11:00 AM
bserrano
Oct 29, 2006 08:46 PM
stardotstar
May 15, 2004 04:12 PM
