Maintenance????
Maintenance????
Well, since I bought the truck used, I am not sure when the last time the oil was changed. I took it to Ford today and the service department advised me since I didnt have any documentation on what maintenance had been done I should let them check it out. I think when he was naming stuff off, he said something about an oil change, check fuel filters, check coolant, check transmission fluid. He said all of this would run me about $550. Do I need all of this done? Let me know what you all think. Thanks.
Anthony
Anthony
HA!! I'll bid $350!
The others are right. Take it to another local shop. $550 is steep. Or you cando it yourself. Nothing major about it.
Coolant should be fine. Just make sure it is up to date with its flashes and have the Venturi T installed if it hasnt been already. Like mentioned above, an oil and filter change along with new fuel filters would be a must and are really easy to do. There are two fuel filters. The 6.4L filters are different from the 6.0L filters in that the one on top of the motor is larger so you cant grab them up for cheap at the International dealership. There is a filter on the frame rail under the drivers seat that will require a 36mm socket to get off. Cant remember what the fuel filter on top of the motor takes
I would change the oil and oil filter, change fuel filter(s), possibly flush transmission (dealer) and check the rest of the fluids. The tranny flush is really the only thing you might have the dealer do, they can check service records though and see when it was last done.
...only if it was done at a FORD dealer and it was put into the VIN record!!
What engine do you have? what tranny? Auto/manual?
Change oil and filter, You can take this to Walmart, or a "lube" place. Just watch them and make sure they are installing the proper oil.
While at lube place have them check both differentials and the trainsfer case if 4X4
Coolant should be fine, If you need to top it off remember to use ford "gold"
There are a few writeups on the fuel filters, it is not a hard job, about 30 minutes total.
Have the dealer flush the tranny, about 120-150, while there have them check Flashes and recalls.,
I have my tranny done every 50K or so.
I'd check the maintenance schedule in your owners manual and do everything as stated, going forward. There is probably a number of things at 15k, 30k, 45/50k, or some such mileage. I'd just do the scheduled maintenance recommended after this time, just oil and filter at this time, and next time in see if there is a 45k/50k maintenance due.
