silencer ring removale
Old Jan 24, 2009 | 11:04 PM
  #46
Zip's Avatar
Zip
Originally Posted by rollerstud98
This is what mine looks like, there are 3 spots hopefully you'll be able to see them where it looks like it was crimped in or something.
Yep that's what mine looks like. Not hard to get out at all with no damage. Can probably put it back in as well.
Old Jan 25, 2009 | 06:40 AM
  #47
Bustaduck's Avatar
Bustaduck
mine must be a late 03 because it doesn't have the crimps in it. Not going to remove the turbo to have it machined out. thanks for the pix.
Old Jan 25, 2009 | 01:12 PM
  #48
rollerstud98's Avatar
rollerstud98
Where did you pry on it to remove it? Just wondering cause I worked it a bit but nothing hard or for very long.
Old Jan 25, 2009 | 02:55 PM
  #49
Zip's Avatar
Zip
I pried from the inside of the ring with a big screwdriver. It didn't take much force to wiggle it out.
Old Jan 26, 2009 | 12:07 AM
  #50
DFLEX's Avatar
DFLEX
hey Zip, can you notice any difference without that ring in there?
Old Jan 26, 2009 | 06:13 AM
  #51
Zip's Avatar
Zip
I haven't really driven it yet since I took it out. I pulled it on Thursday and worked from Friday till now so it has been sitting in the yard. I'll drive it a little more this week once I get/find some more coolant.
Old Jan 27, 2009 | 09:20 PM
  #52
Zip's Avatar
Zip
I didn't really notice anything different in either sound or performance. I think I'll put it back in tomorrow.
Old Jan 27, 2009 | 09:29 PM
  #53
DFLEX's Avatar
DFLEX
Thanks Zip, I won't even bother taking mine apart then. I guess my truck is already as loud as it can get....
Old Jan 28, 2009 | 04:17 PM
  #54
Zip's Avatar
Zip
I took some pictures today when I put the ring back in.
Picture 1 is the turbo with the ring in place.
Picture 2 is the turbo minus the ring
Picture 3 is the side of the ring you see when looking into the turbo
Picture 4 is the inside of the ring
Old Nov 17, 2011 | 12:27 AM
  #55
ua-usa's Avatar
ua-usa
I have 2004 king ranch with a cast silence ring
I just used Air cut off tool cut it out and used dremel to smooth edges out no need for taking it to get it machined off.
P,s you dont need to remove entire turbo just unscrew the front 6 bolts and remove front part. I was in process of removing and putting EGR DELITE kit and new Oil pump so my turbo was out anyway ......
<a href="http://s92.photobucket.com/albums/l23/viktorpugach/Ford/?action=view&amp;current=IMG_2318.jpg" target="_blank"><img src="http://i92.photobucket.com/albums/l23/viktorpugach/Ford/IMG_2318.jpg" border="0" alt="Photobucket"></a>
<a href="http://s92.photobucket.com/albums/l23/viktorpugach/Ford/?action=view&amp;current=IMG_2323.jpg" target="_blank"><img src="http://i92.photobucket.com/albums/l23/viktorpugach/Ford/IMG_2323.jpg" border="0" alt="Photobucket"></a>
<a href="http://s92.photobucket.com/albums/l23/viktorpugach/Ford/?action=view&amp;current=IMG_2326.jpg" target="_blank"><img src="http://i92.photobucket.com/albums/l23/viktorpugach/Ford/IMG_2326.jpg" border="0" alt="Photobucket"></a>
<a href="http://s92.photobucket.com/albums/l23/viktorpugach/Ford/?action=view&amp;current=IMG_2321.jpg" target="_blank"><img src="http://i92.photobucket.com/albums/l23/viktorpugach/Ford/IMG_2321.jpg" border="0" alt="Photobucket"></a>
<a href="http://s92.photobucket.com/albums/l23/viktorpugach/Ford/?action=view&amp;current=IMG_2327.jpg" target="_blank"><img src="http://i92.photobucket.com/albums/l23/viktorpugach/Ford/IMG_2327.jpg" border="0" alt="Photobucket"></a>
Old Nov 24, 2011 | 09:58 AM
  #56
ItsMREMT's Avatar
ItsMREMT
so what was the outcome?
Old Nov 24, 2011 | 11:19 AM
  #57
ua-usa's Avatar
ua-usa
Well not a big difference in noice when idling, but over 2500 rpm it sure has a higher pitch noise like f117 lol, but again I have full turbo back exhaust with cold air intake, and bully dog.
Now if u were referring to oil cooler and egr kit, it sure made a difference : truck engine runs around 200 degree cooler,takes longer to warm up my heat air( frozed my a$$ last night) before it heat my cabin lol
Was at bend Oregon 19f at night lol
Pescs334
1983 - 2012 Ranger & B-Series
Jun 14, 2014 02:28 PM
73f250cummins
Dec 5, 2013 06:22 PM
2006powerstroke90
Nov 30, 2011 09:46 PM
1bad04
Jan 13, 2011 06:24 AM
bigtuna128
Dec 2, 2009 07:08 PM
