Coolent leaks.. Help!
Old Jun 14, 2014 | 08:59 AM
Pescs334's Avatar
Pescs334
Ok so about a month ago I rebuilt the front end on my ranger. Core support header panels headlights and so on. (on my profile) Well once all done the water pump was leaking so I replaced that as well, it took me about 4 complete installs and removale before I figured out the new o ring had a crack. Once I replaced that part it sealed proper stopped leaking but now it's back.. It looks like it's leaking from the water pump again because I can see it dripping off the bottom pully dead center. Well the only thing with coolent above there is the water pump I just don't know how it's leaking again.. I even used gasket sealer and all. Any ideas or tips thanks
Old Jun 14, 2014 | 09:00 AM
Pescs334's Avatar
Pescs334
By the way
It drippy slowly never seams to drip constant. Sometimes won't drip at all or leak a drop after driving all day but will leak a bit out after sitting over night. Very random never while hot.
Old Jun 14, 2014 | 01:08 PM
pawpaw's Avatar
pawpaw
Water pump shaft seal maybe. Does it have a runny nose at the seal weep hole, or is it around one of the mounting bolts, or studs????
Old Jun 14, 2014 | 01:14 PM
Pescs334's Avatar
Pescs334
Well originally it was the or ring that goes inside to intake hole for the lower radiator hose. It seams to be around the on the lower side of it because the pump is not wet at all on the top
Old Jun 14, 2014 | 01:15 PM
Pescs334's Avatar
Pescs334
I'm gonna have to take a closer look later. I've been working up till today
Old Jun 14, 2014 | 02:28 PM
pawpaw's Avatar
pawpaw
OK, well have a close look at the channel that the "O" ring seats in, to make sure its not rusty, or has debris in it & lube the "O" ring when installing, so it doesn't get roughed up. The other surface the "O" ring seals on, needs to be clean & smooth too.
Use a torque wrench to slowly work the pump fasteners up to spec in say 3 steps, in a cross hatch pattern, so as not to warp the pump casting, if you discover its leaking there again.
Wicked Endings
Jun 14, 2010 08:10 PM
rolltide3006
Jan 5, 2010 11:09 AM
Arno F100
Sep 30, 2009 04:07 PM
Greenmachine_76
May 26, 2009 11:44 AM
Steve_250
Nov 23, 2008 05:13 AM
