Turbo Silencer Ring
Old Jan 12, 2011 | 10:37 AM
1bad04's Avatar
1bad04
Turbo Silencer Ring
Looking for some info on what you guys think about removing the silencer ring from my 04 turbo. Yes i know it has to be machined off. I all ready checked. But my question is if will improve the sound any? I have read a lot about this on other forums and got a lot of mixed opinions on this. For those who will say it will not make the turbo whistle any loader,why is called a silencer ring?
Old Jan 12, 2011 | 11:36 AM
adambomb's Avatar
adambomb
i don't know anyone who has done this to there turbos but i saw this on youtube a while ago about doing the same thing you are talking about.
YouTube - removal of silencing ring on 6.0 powerstroke
Old Jan 12, 2011 | 11:42 AM
1bad04's Avatar
1bad04
Same vid I seen last night! But I sure wouldnt hack it off like that idiot did. LOL
Old Jan 12, 2011 | 12:05 PM
High Binder's Avatar
High Binder
Wow, that's not something I would ever do.
Old Jan 12, 2011 | 12:38 PM
lawnboy1965's Avatar
lawnboy1965
What a hack job.
Old Jan 12, 2011 | 12:41 PM
adambomb's Avatar
adambomb
..... and after grinding off chunks of his turbo he can also show you how to make a smoke switch.
Old Jan 12, 2011 | 01:24 PM
davidkstyler's Avatar
davidkstyler
The ring appears to direct air into the center of the blades, cutting it off cannot improve the smooth flow of air into the turbo.
Did you notice the dusted tubo blades? A good reason not to use aftermarket filters.
Old Jan 12, 2011 | 01:30 PM
adambomb's Avatar
adambomb
i don't think any one of that's posted has done this. i would NEVER that's forsure. looks super risky for little sound and what not you get from doing it.
Old Jan 12, 2011 | 02:42 PM
Kert0307's Avatar
Kert0307
I don't think that this is too good of an idea either. I'm pretty sure that ring is there to help reduce "chopping" of the turbo, something that the 7.3's had a few problems with when they were running higher power. Think of it like if you put the wrong pitch prop on a boat and it wont hook up out of the hole, just sit there and spin...
Old Jan 12, 2011 | 02:55 PM
ljutic ss's Avatar
ljutic ss
[quote=Kert0307;9814121]I don't think that this is too good of an idea either. I'm pretty sure that ring is there to help reduce "chopping" of the turbo, something that the 7.3's had a few problems with when they were running higher power. Think of it like if you put the wrong pitch prop on a boat and it wont hook up out of the hole, just sit there and spin...[/quote
It's called cavitation
Old Jan 12, 2011 | 03:15 PM
1bad04's Avatar
1bad04
Why dont the bigger after market turbos like ATS have them?
Old Jan 12, 2011 | 03:25 PM
Kert0307's Avatar
Kert0307
The ATS for the 7.3 does have it. Not sure about the 6.0
Old Jan 12, 2011 | 03:39 PM
1bad04's Avatar
1bad04
ATS and Turbonetics Definitely do not have them for the 6.0l
Old Jan 12, 2011 | 05:26 PM
psdmikee's Avatar
psdmikee
Maybe the dumbest thing I've ever seen.
wtf
Old Jan 13, 2011 | 06:24 AM
1bad04's Avatar
1bad04
I cant believe that know one on here has done this or at least no someone who has. It seems to be talked about heavily on other site if you look it up. Guess I will have to be to test pilot and have my buddy who owns a machine shop cut mine off and I will let you all know if it works.
beauprepa
Mar 29, 2017 09:43 AM
Regulator1988
Apr 2, 2012 02:02 AM
2006powerstroke90
Nov 30, 2011 09:46 PM
04redstroker
Mar 8, 2009 01:50 AM
Fully_Loaded
Jul 11, 2007 12:10 AM
