Boost Pressure
Old Jan 2, 2009 | 10:11 PM
Izzy351's Avatar
Izzy351
Originally Posted by hucka1a
I don't know. It's an autometer ultralite. I'll try it tomorrow and see if it will set a SES. I haven't had a chance to get on it since I swapped pcm's. I do know that before I disconnected the red line. I would hit 15# at wot. I disconnected the line and it went to 18#. After I cleaned and painted the IC pipes I could hit 22#. And now that winter is here it reads 25#. How could I check my gauge? Maybe with a compressor and a regulator?
That's exactly how I'd do it....
Old Jan 2, 2009 | 10:15 PM
megawatt00's Avatar
megawatt00
If anyone needs a boost fooler I have one that I made up. I got the "codes" tunes so i don't need it.
Old Jan 2, 2009 | 10:21 PM
hucka1a's Avatar
hucka1a
I'm gonna see if I can get an SES light with the new pcm, if not I'll be heading to lowes to get some fittings to check the gauge. (I know you prolly think I'm full of chit lol, but I really have been getting those readings.)
How do you like the codes tunes Jim. I've got a boost fooler made, I just haven't made a bracket for it yet.
Old Jan 2, 2009 | 10:35 PM
megawatt00's Avatar
megawatt00
The codes tunes are nice. I tried to throw the ses light and haven't been able to do it!
I have the fooler but no bracket. I also have a bunch of resistors to make up a AIH delete fooler. I have to solder them up.
Old Jan 3, 2009 | 01:11 AM
STROKIN'IT7.3's Avatar
STROKIN'IT7.3
Jim, could you send me or post up a diagram of this AIH fooler? Interested in doing this but don't wanna throw a code. Thanks bud
Old Jan 3, 2009 | 08:47 AM
danskool's Avatar
danskool
Go Bills !
I can only get 16 WOT. Waist gate tube disconnected. 17
My Dads is the exact same.
Cleaned all boots.
Tested for leaks
No exhaust leaks.
Swapped out 3 or 4 different gauges.
Old Jan 3, 2009 | 09:11 AM
Izzy351's Avatar
Izzy351
//SNIP//
I don't think you're full of chit, I just think you're getting bogus readings. Unless you have a flashed PCM and don't know it, you shouldn't be getting anywhere near those numbers in stock tuning. Especially since you're not getting codes. I'm reasonably sure the older PCM still threw codes & defueled at 22 & 25psi respectively (I just don't know that for sure), so that's why I say that.
Old Jan 3, 2009 | 11:25 AM
hucka1a's Avatar
hucka1a
I haven't had a chance to get out on the highway yet. Heading over to a buddy's house I did hit 24# and no SES. I didn't have enough road to get to 25. I'll post back later when I can get a highway run.
Old Jan 3, 2009 | 02:28 PM
DCSpecial's Avatar
DCSpecial
Cleaned all boots.
Tested for leaks
No exhaust leaks.
Sounds right if you don't have any aftermarket chip/programming.
Old Jan 3, 2009 | 04:36 PM
Tenn01PSD350's Avatar
Tenn01PSD350
Who cares? It is a soft code and does not affect the truck at all. The only time I clear it is when I run a contribution test because I have to or the test will not run.
Old Jan 3, 2009 | 06:00 PM
Steve_250's Avatar
Steve_250
Jim, I can't find the thread about doing this mod, point me please?
Old Jan 3, 2009 | 08:57 PM
hucka1a's Avatar
hucka1a
Well, I didn't get any where near a highway today. I did make it to Lowe's and got enough fittings to hook a compressor to my boost gauge. I'll check it out tomorrow before I install the tugger.
Old Jan 3, 2009 | 09:40 PM
  #28
megawatt00's Avatar
megawatt00
I'll mail you one when I make them up.
You are 100% right Mike. I got the idea to make them up after reading the thread where Curtis was having this issue.
Here it is Steve:
https://www.ford-trucks.com/forums/6...cant-wait.html
cannonsms
Mar 15, 2014 08:37 AM
richdawg
19
Apr 25, 2012 10:54 AM
dyoung14
Apr 28, 2009 07:26 AM
firemanbird
Aug 9, 2006 10:34 PM
greenhedhntr
Nov 14, 2004 01:02 PM
