what do these turbos make for boost from the factory? at stock settings?
I see you are putting the turbo on the '86 6.9. Let us know how it goes and what boost you get once installed. Pic of the install would be great. Good luck.
Oh I didn't even see that.
With a chip these turbos can see 25+ PSI of boost. However, you generally don't want to sustain above 25 psi for very long, or you can end up thrashing the bearings. Since you are putting this on a 6.9L, I'm sure your boost levels will be low enough to keep the turbo happy.
i will post yall some pics of it on the truck, if you want to see some now go and look on in my gallerys, and i probly wont exceed 13-15 psi of boost for very long my brand new headgaskets might not like that very much
