idle issues!
Old Jan 2, 2009 | 06:35 PM
kupiec20's Avatar
kupiec20
idle issues!
when i first start my 97psd she will idle normal for about a min. then she'll idle high - if i tap on the pedal she'll come back down only to come up again!this should be a an easy one for you guys!
Old Jan 2, 2009 | 06:44 PM
c00nhunterjoe's Avatar
c00nhunterjoe
cold weather programming, its normal, the ebp valve should kick on too.
Old Jan 2, 2009 | 07:35 PM
tjbeggs's Avatar
tjbeggs
Never heard of an OBS having high idle. I don't think this is normal.
Old Jan 2, 2009 | 07:36 PM
c00nhunterjoe
before i installed the superchip in mine it would do it. my idle would bump up and the valve would close. not to 1200 or anyting crazy like that but the idle would raise a few hundred rpm
Old Jan 2, 2009 | 10:31 PM
JethroF250's Avatar
JethroF250
Katie's (Missy) does it to. i noticed it idles at bout 8 or 900 like the SD's. it should be normal. i wish mine did it lol she just lopes and then smooths out to 600
nelstone74's Avatar
nelstone74
I don't think it is normal, and I saw in his sig that he has a superchip already in. I wish I had a high idle
Old Jan 2, 2009 | 11:11 PM
c00nhunterjoe
how high does it idle? is the ebp valve coming on?
Old Jan 3, 2009 | 12:33 AM
joe_13894's Avatar
joe_13894
I wish mine did to. I started mine up today at 25°F. Starts up just fine, but it lopes like mad until I start down the highway.
I've been considering adding a manual high idle switch. Both for cold starts, and for camper battery charging.
Old Jan 3, 2009 | 05:21 PM
kupiec20's Avatar
kupiec20
This Post Is Actually For My 2002 7.3 If That Makes A Difference, I Just Thought Id Ask Youz Guyz!
Old Jan 3, 2009 | 05:25 PM
kupiec20's Avatar
kupiec20
HOW DO YOU KNOW IF THE EBP VALVE IS COMING ON?
Old Jan 3, 2009 | 05:41 PM
IDMooseMan's Avatar
IDMooseMan
You can hear a "hissing" sound.
Old Jan 3, 2009 | 05:56 PM
tjbeggs's Avatar
tjbeggs
Yep that makes a difference. The Super Duty's do have a high idle.......
Old Jan 3, 2009 | 06:28 PM
84-250's Avatar
84-250
my 94.5 kicks up the idle to 900 when cold. ebpv should come on but the solinoid is stuck. AFAIK it is still running stock programming.
Old Jan 4, 2009 | 06:01 AM
kupiec20's Avatar
kupiec20
is there a way to disable my ebpv on my 97psd, it use to make a hiising sound, but now its still hissing with a very deep growling sound, any idea what that added sound is?
ZombiePopper
Oct 1, 2014 11:59 AM
acerockola77
1983 - 2012 Ranger & B-Series
Dec 4, 2003 02:08 AM
nantruckit
Nov 29, 2003 07:46 PM
