trans problem
Old Jan 1, 2009 | 05:29 PM
don77's Avatar
don77
trans problem
i got bad tran question is what would go bad in trans from pulling it with driveshaft in
Old Jan 1, 2009 | 08:56 PM
kawa's Avatar
kawa
Welcome to FTE.
Don, I don't understand your question, give more details as to what you were doing at the time the problem occurred and exactally what occurred.
Rog
Old Jan 1, 2009 | 09:22 PM
don77's Avatar
don77
thats was it just wondering if i messed anything up a rebiuld would fix from towing
Old Jan 2, 2009 | 06:42 AM
tjbeggs's Avatar
tjbeggs
A rebuild would probably fix it but there are a number of things that could have been hurt so its hard to say for certain. Is the truck 4wd? If so it could be something in the transfer case? How far was the truck towed?
Old Jan 2, 2009 | 05:10 PM
don77's Avatar
don77
200 in 2wdh its 4x4
Old Jan 2, 2009 | 05:11 PM
c00nhunterjoe's Avatar
c00nhunterjoe
wow, 200 miles is alot to be flat towed on an auto. you should has put the t-case in neutral and you would have been fine. you most likely shreaded the bearings in the tranny and sent metal throughout the clutches. it can be overhauled as long as the case didnt get damaged when things overheated.
deljac
Apr 18, 2016 08:35 PM
Xwarrior86
Feb 3, 2016 09:09 PM
bcaughhorn
Jun 12, 2015 10:47 AM
gti
26
Jul 17, 2010 03:30 AM
k_frocken
Nov 10, 2002 11:50 AM
