How to Walbro pump
Old Jan 1, 2009 | 03:01 PM
Farmboypowerstroke's Avatar
Farmboypowerstroke
How to Walbro pump
How do i hook my walbro pump up? just take the old one off, hook the + and - and good to go? Once thats done can i turn the key on and see if it pumps?
Old Jan 1, 2009 | 03:21 PM
PaysonPSD's Avatar
PaysonPSD
FTE Remembers
Here's a pictorial on my Walbro pump install. LINK
Old Jan 1, 2009 | 03:47 PM
Farmboypowerstroke
cause i got it hooked up, but it won't pump
Old Jan 1, 2009 | 04:25 PM
PaysonPSD's Avatar
PaysonPSD
FTE Remembers
I misunderstood your post.
Check fuse 19 under hood, 20A Maxi fuse for fuel pump motor.
Old Jan 1, 2009 | 05:00 PM
Kwikkordead's Avatar
Kwikkordead
Is there power to the + post? You have to be quick on that one, turn on the key and test it within 7 seconds or so.
Do you hear it running?
Old Jan 1, 2009 | 05:59 PM
Farmboypowerstroke
I did it was blown, replaced still nothing
Old Jan 1, 2009 | 06:01 PM
Farmboypowerstroke
the stock pump worked when i took it off
took stock pump off, put walbro on, didn't work. unhooked batteries,
put stock pump on, it pumped, but not like it should have i don't think, unhook
batteries, put walbro on, nothing, unhooked batteries, checked fuses, the fuel
pump/PCM is blown, replace still nothing. i kept the PCM unhooked, cause i took my chip out
Old Jan 1, 2009 | 06:06 PM
PaysonPSD's Avatar
PaysonPSD
FTE Remembers
The fuel pump will not run without signal from PCM to control it. There is a fuel pump monitoring lead from the pcm. Hook up PCM, make sure fuse is ok, and attempt a start. If fuse blows you may have a bad pump, shorted pump motor winding.
Edit: Before you try to start turn key on, you should here pump run for about 20 seconds. The Walbro is harder to hear then the stock pump.
Old Jan 1, 2009 | 06:12 PM
Farmboypowerstroke
I won't be able to start the engine, cause i have a few things off of it. I tried a few times when the pcm was plugged in, fuses ok, and still nothing
Old Jan 1, 2009 | 06:46 PM
fxstbchopper's Avatar
fxstbchopper
It could be the fuel shut off switch. It is in the passenger side kick panel.
Old Jan 1, 2009 | 07:05 PM
PaysonPSD's Avatar
PaysonPSD
FTE Remembers
No need to start truck to est to see if pump will run. You can always run a hot lead off the battery to see if the new pump works. If it doesn't run then the - or ground lead is bad or the pump is bad.
Do you have a volt meter. Check to see if the + lead is hot with the key on. Also check the - lead for ground. Also ceck to make sure pump motor winding is not shorted.
Old Jan 1, 2009 | 07:39 PM
Farmboypowerstroke
The new walbro pump is no good, hook it to the battery doesn't work
Old Jan 2, 2009 | 10:08 AM
PaysonPSD's Avatar
PaysonPSD
FTE Remembers
Sorry to hear that. Bench test the next one before install.
Old Jan 2, 2009 | 06:01 PM
OUTPLAYN's Avatar
OUTPLAYN
Anyoe else usig this pump?
And how is it working out for them????
jr2000sd
Sep 23, 2015 08:24 AM
DIYiT
Mar 5, 2013 11:57 AM
superduty4x4
25
Aug 2, 2011 09:18 PM
John7894
Aug 6, 2010 11:26 AM
lmnr0026
Oct 29, 2009 09:01 PM
