89 Explorer No High Beams
Old Dec 18, 2008 | 11:16 AM
mudmentwo's Avatar
mudmentwo
Driving Down The Road The Other Evening With The High Beams On I Herd A Click And Lost The High Beams . What Should I Check First .
Thanks John
Old Dec 18, 2008 | 01:34 PM
87 XLT's Avatar
87 XLT
If your low beams work the dash switch is OK.
If flash to pass works the high beam fuse & bulbs are OK & you need to check the dimmer/multifunction switch.
I presume this is a 1999.
Old Dec 18, 2008 | 03:52 PM
mudmentwo's Avatar
mudmentwo
I Checked It Out Today And It Was A Fuse In Number 33 Slot , I Hope When I Try The Lights For A While Tonight They Don't Blow Again ,
Thanks John
Old Dec 18, 2008 | 04:47 PM
87 XLT's Avatar
87 XLT
Yeah, sometimes fuses just blow for no good reason.
About 19 years ago i replaced the cruise control fuse on my 87 Ranger, & the fuse is still in there, no more problems.
Good luck with it.
Old Dec 18, 2008 | 05:11 PM
mudmentwo's Avatar
mudmentwo
I Have Another Problem My Remote Only Opens The Doors But Will Not Lock Them , Any Ideas
Old Dec 18, 2008 | 05:56 PM
steve(ill)'s Avatar
steve(ill)
the little motor/ solenoids in the door are probably bad. not uncommon after 10 years.
05Eddie
Nov 8, 2012 07:27 AM
JKnSD
1983 - 2012 Ranger & B-Series
Jul 29, 2011 05:04 PM
hvanegas
Jun 7, 2006 06:10 AM
jjlrrw
1997 - 2003 F150
May 16, 2005 12:41 PM
JEDM3
Dec 6, 2003 08:34 AM
