Prob with your high beams or are you trying to mod your switch so your fogs work with your high beams on? If its the latter....Do a search for "headlights, fog" in this forum and there are a few threads that have instructions on how to make the mods and a couple of em have the wiring mods.
I want to install in series another method of turning on the highbeams. I need to locate the high beam wire after it leaves the stalk but before it plugs into the relay to tell the system to turn on the high beams and indicator. I would like to do this some where under the dash
I did find a diagram from an '05 looks like a 12V signal is sent to a high beam relay then the output feeds the HB filament and indicator. The wire is labeled 275 YE and goes to the Central Junction Block pin 2. If I could locate this block it would be very helpful.
