Tried to look up a center support bearing on partsamerica, autozone, and napa, but I end up getting like 10 different part numbers and 10 different prices.
Anyone have the part # I need? Truck is a 2004 F250 Crew Cab 4x4 king ranch 6.0 diesel. Automatic tranny. Thanks!
Talk to Ed (FTE Partsguy). He'll be able to give you the Ford part numbers, and quote you a price for OEM parts, probably better than you would get at your local stores.
Does F81z 4800 EA change into the part number you gave me??
well, now you made me double check.
per the catalog if I enter vin, search for 4x4, search for 156 wheel base it comes up with two choices. both are for a M6OD trans and both use E4TZ4800A center brg.
Now if I enter the ID number from your driveshaft 3C344K145CFB it puts me into a different parts list that was not a option when doing just the vin number and that says use F81Z4800EA center support brg. and for a 5R110 Transmission
so I entered vin number number into Ford data base and it says use F81Z4800EA
so i'm glad you question me on this and I double checked, now did you get F81Z4800EA and there is a problem or ?
No the only reason I ask is that I've called 4 different local dealers and I get three different numbers two have given me the first number you gave me, and the third did a more detailed look up like you did on the second time and came up with the 4800EA number. I have not ordered anything yet, I just am trying to get consistency on a part number before i buy something. I appreciate your time and effort, I'll be ordering soon!
Bill
you are welcome. Kinda embarrass I missed it the first time.
I should have checked the trans type, but when you are not given a choice why would you question it?
