Steering column bearings... NumberDummy?
I pulled the steering column out of my 1966 F100 4x4 tonight and realized it could really use new bearings before I reinstall it after the new firewall cover is in place.
Does anyone happen to have the part numbers for the upper and lower steering column bearings in my truck? I know they are different part numbers...
Cheers,
Dion
https://www.ford-trucks.com/forums/7...n-rebuild.html
NumberDummy has been there done that!
Here's another one as well, these folks are great to deal with,
Carolina Classics, Obsolete Ford Truck Parts, truck part, ford truck part, truck body parts, classic truck part, pickup truck part, old truck part, classic ford truck part, antique truck part, old ford truck part, auto truck part, ford truck restorat
MSRP: $10.68 // FTE Ford Dealer Parts Dept sponsor PARTSGUYED.COM price: $7.69. (PartsGuyEd: Horizon Ford in Seattle WA).
Fits: 1961/66 F100/250 4WD Upper only / 1961/66 F100/250 2WD & F350/600 Upper & Lower / 1967/72 F350 Upper & Lower / And etc etc etc.
F23Z3517B (replaced E1FZ3517B, DOAZ3517A, C7SZ3517D & C3AZ3517A) .. Steering Column Bearing / Available from Ford.
MSRP: $19.97 // PARTSGUYED.COM price: $14.38.
Fits: 1966 F100 4WD Lower only / 1967/79 F100/250 4WD Lower only / 1981/97 Escort/Lynx/Tempo/Topaz / Myriad 1963/79 Passenger Cars.
The upper and lower bearings have sleeves.
B1AZ3518A .. Bearing Sleeve-Use w/C3DZ3517A / Available from Ford.
MSRP: $10.12 // PARTSGUYED.COM price: $7.28.
C6TZ3518A .. Bearing Sleeve-LOWER only / Fits: 1966 F100 4WD / 1967/72 F100/250 4WD / Obsolete
F. X. CAPRARA FORD in Pulaski NY has ONE = 315-298-5114.
KLIMESH MOTOR SALES in Calmar IA has ONE = 563-562-3241.
JST AUTOMOTIVE in Lebanon TN has ONE = 615-443-3086.
BERGE FORD in Mesa AZ has ONE = 480-497-1111.
DON SANDERSON FORD in Glendale AZ has FOUR = 623-842-8682.
GREEN SALES CO. in Cincinnati OH has FOUR = 800-543-4959 / 513-731-3304.
Everything makes sense except the lower bearing sleeve... I didn't see on my column when I pulled it apart last night. I definitely noticed that the upper and lower bearings weren't the same, and that the upper bearing had a sleeve that fits on the shaft and down into the bearing... but I didn't see the same sort of thing on the lower bearing.
I'm going to try and snap a picture of it this afternoon and will post again later so that I'm sure of what I have.
Cheers,
Dion
This is what I have on the bottom of my steering column shaft:
The bearing definitely was sitting on it... so is this the correct bearing sleeve, part #C6TZ3518A? If so, I'll just reuse it... if not, then I'm not really sure what it would look like.
Cheers,
Dion
The upper sleeve nestles inside the bearing. The lower sleeve is stretched over the outside of the bearing.
The sleeve/bearing is then inserted into the lower section of the mast jacket (steering column cover).
F23Z3517B .. Lower Bearing: 1 3/16' O.D. / 3/4" I.D. / 9/32" thick.
C6TZ3518A .. Lower Bearing Sleeve: No O.D. listed / 1.04" I.D. / .468" thick.
The parts catalog exploded view of the entire column would be a big help describing how all this jazz fits together.
Pictured here: 1964/72 Ford Truck Parts Catalog / Illustration Section 35, Page 9. This catalog is available on a CD from hipoparts.com for $22.00 (US).
I did buy one of those Parts Manuals today... so hopefully I can start looking this stuff on my own!
Cheers,
Dion
