Steering column bearings HELP!
Old Sep 25, 2014 | 09:35 AM
Roger C's Avatar
Roger C
I'm reworking my steering column so the emergency flasher button is on the column. I robbed the column parts from my 76 F250 4x4. Well the turn signal ring that on the 66 has a bearing in the front of the ring. That bearing will not fit on the 1976 ring even though the only difference between the two is the 1976 has the cutout for the flasher button. I need to find a part number for the bearing that will fit the 76 ring. it is a smaller outside diameter than on the 66 bearing. Since ring is off a 4x4 the upper bearing is snap ringed to the shaft behind the ring. Will the 1973 to 1976 2 wheel drive have the bearing I need?
Old Sep 25, 2014 | 01:54 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
I need to find the part number for the bearing that will fit the 76 ring. it is a smaller outside diameter than on the 66 bearing. Since ring is off a 4x4 the upper bearing is snap ringed to the shaft behind the ring. Will the 1973 to 1976 2 wheel drive have the bearing I need?
F23Z-3517-B (replaced E1FZ-3517-B, D4TZ-3517-A, C7SZ-3517-D, C3AZ-3517-A) .. Upper Steering Column Bearing / Available from Ford
MSRP: $21.45 / FTE Ford Dealer Parts Dept sponsor: horizonpartsguy.com online price: $15.44 / Horizon Ford Truck Center - Seattle (Tukwila) WA
1973 F100/350 from serial number U60,001 / 1974/79 F100/350 / Misc: Aerostar/Ranger/Bronco II/Explorer / Misc 1963/90's Passenger Cars.
The B1AZ-3518-A nylon sleeve used with the original C3DZ-3517-A upper bearing will not work with the F23Z-3517-B bearing.
E2AZ-3518-C (replaced D1AZ-3518-A & E2AZ-3518-A) .. Upper Steering Column Bearing Sleeve / Obsolete
1973 F100/350 from serial number U60,001 / 1974/77 F100/350 / 1978/79 F100/350 without tilt wheel / Misc 1963/90's Passenger Cars.
CARPENTER NOS OBSOLETE PARTS in Concord NC has 107 = 800-476-9653. Carpenter also has 50 of F23Z-3517-B
Bruce Schena
Oct 13, 2017 07:26 AM
CountryBumkin
Mar 30, 2017 07:29 AM
Chevmn56
13
Aug 31, 2015 12:08 PM
Marky48170
Oct 7, 2012 07:30 AM
bluestang65
Sep 2, 2010 09:10 AM
