Annoying auto lock
Old Dec 13, 2008 | 06:40 PM
heymrdj's Avatar
heymrdj
Annoying auto lock
I was wondering if there's any particular way to leave my truck running and lock the #%$%#$& doors.
Exhibit A: I frequent long distance trips of 250miles+, upwards of 1,000 miles in 1 day a few times a year.
Exhibit B: Cold mornings, iced windshield, trying to warm the engine to get some heat to defrost stuff.
In both cases I can't leave the vehicle unattended because the doors automatically unlock if I lock them. The 20 minute ride to work sucks because the first 10 minutes it's warming up. It's agitating in winter that the huge mechanical fan cools the engine even though the engine is struggling to get warm. Also when I'm running to a rest stop to pee real quick and i've been cruising at 80mph, I don't want to do the unhealthy thing and go form 80-0 in less than a minute, shut it off, start it 2 minutes later, and go 0-80 in a minute. I want to just idle it.
I keep both a set of spare keys, a spare fob, and i know the key code to my keypad. I'm not going to get locked out, I want it to stop protecting me from that.
Old Dec 13, 2008 | 09:07 PM
4DTech's Avatar
4DTech
When you get the vehicle running close the door then push the 7-8 9-0 buttons at the same time this will lock all doors and vehicle will stay running. Works for my vehicles just fine..
Old Dec 13, 2008 | 09:15 PM
heymrdj's Avatar
heymrdj
I'll give this a try soon and report on it. Thanks alot
Old Dec 13, 2008 | 09:40 PM
heymrdj's Avatar
heymrdj
Worked perfectly . Thank you so much!
Old Dec 13, 2008 | 09:44 PM
4DTech's Avatar
4DTech
No problem.....
Old Dec 17, 2008 | 07:26 AM
alwaysfords41's Avatar
alwaysfords41
Ditto on the thanks. I was always pissed off that with my 99 I could just hit the lock button and leave it running and the 03 would kick the locks back up immediately. So after 5 years I've got a new feature. Let me down easy, was this in the manual???
Old Dec 17, 2008 | 08:41 AM
Johnny Langton's Avatar
Johnny Langton
Yes, it is.
JL
Old Dec 17, 2008 | 09:55 AM
Brandon_01's Avatar
Brandon_01
Good to know. Thanks, guys!
Old Dec 17, 2008 | 12:40 PM
pitrow's Avatar
pitrow
another quick one that's in the manual that not many people know about, is if you unlock the doors via the keypad on the door, if you press the "3" button after it unlocks the driver's door, it will then unlock the rest of the doors too. Saves time if you need to get into the back seat, or cargo area. No need to unlock, open the door, and hit the switch. Just press one extra button and everything is open.
Old Dec 17, 2008 | 02:09 PM
alwaysfords41
That one I knew and use, my 99 worked that way as does my 03/04.. I must have just missed a paragraph in the 03 manual, or just assumed they had modified the ability to lock the doors with the motor running.
Old Dec 17, 2008 | 08:34 PM
4DTech's Avatar
4DTech
Oh well if no one else knows either. If you press the 3/4 you unlock all the doors, but if you press 5/6 (if it is a car) it will pop the trunk.. Just an extra.... And if you type in the wring code I think it's 3 times but maybe up to 5 it will disable the keypad for 20 minutes..
Mtncrash1
6.7L Power Stroke Diesel
Jan 5, 2015 08:02 PM
BarterOnlycom
Apr 26, 2013 08:33 PM
babstinger
Sep 6, 2010 06:44 PM
Majere26
1997 - 2003 F150
Jan 19, 2009 04:45 PM
F-Liner
Kansas Chapter
Oct 10, 2005 07:05 PM
