When I start my truck it runs fine. After it warms up it starts to smoke (white smoke) heavily. The truck runs fine besides the smoke. What could it be? I replaced the MAP sensor and the TPS sensor because that's what the guy at Autozone suspected. Any suggestions???
white smoke sounds like water, Do you have something cracked, head gasket, worse yet, head. Did it over heat recently or sense it started blowing the white smoke. Do you smell antifreeze
Thanks! Um okay....it originally started driving on the highway the truck started to shake then lossed all power I would throttle and it would take a while to pick up speed. Got it towed home and started the truck It was leaking gas out of the exhaust, white smoke and shaking terribly. I replaced the MAP sensor and now it doesn't leak gas or shake, it just smokes. Hope that helps
Pull the codes yourself, see fordfuelinjection.com for the proceedure. Record them and post them here, we'll help you out.
You'll need a compression tester, which screws into the spark plug hole of each cylinder. Then you turn the engine over and record the maximum reading. All the cylinders should be pretty close to one another, one or two that are much lower can signal a problem.
