Help!!
Old Dec 12, 2008 | 05:44 PM
cacree's Avatar
cacree
Help!!
When I start my truck it runs fine. After it warms up it starts to smoke (white smoke) heavily. The truck runs fine besides the smoke. What could it be? I replaced the MAP sensor and the TPS sensor because that's what the guy at Autozone suspected. Any suggestions???
Thanks!
1994 F 150 351 W 4x4
Old Dec 12, 2008 | 05:52 PM
Jeff Dodson's Avatar
Jeff Dodson
white smoke sounds like water, Do you have something cracked, head gasket, worse yet, head. Did it over heat recently or sense it started blowing the white smoke. Do you smell antifreeze
Old Dec 12, 2008 | 05:55 PM
cacree's Avatar
cacree
I don't think so I will look it over some more. I don't smell anitfreeze though and it didn't overheat when the problem started.
Old Dec 12, 2008 | 06:03 PM
quicklook2's Avatar
quicklook2
welcome to fte.
a tad more info on the truck would help.
Old Dec 12, 2008 | 06:08 PM
cacree's Avatar
cacree
Thanks! Um okay....it originally started driving on the highway the truck started to shake then lossed all power I would throttle and it would take a while to pick up speed. Got it towed home and started the truck It was leaking gas out of the exhaust, white smoke and shaking terribly. I replaced the MAP sensor and now it doesn't leak gas or shake, it just smokes. Hope that helps
Old Dec 12, 2008 | 06:12 PM
quicklook2's Avatar
quicklook2
codes?
check compression?
were you off roading or drag racing or anything else like that?
mileage?
stay out of autozone and if you can't at least do not get advice there.
Old Dec 12, 2008 | 06:17 PM
cacree's Avatar
cacree
No sure how to check compression. I am an idiot when it comes to these things I just don't have the money to take it anywhere right now.
I had a friend decode it and it came back with like 22 different codes
It has 158,000 miles on it
No, no offroading or drag racing just driving down the highway at about 65mph.
Thanks for the tip on autozone and for all the help!
Old Dec 12, 2008 | 06:44 PM
Virto's Avatar
Virto
Pull the codes yourself, see fordfuelinjection.com for the proceedure. Record them and post them here, we'll help you out.
You'll need a compression tester, which screws into the spark plug hole of each cylinder. Then you turn the engine over and record the maximum reading. All the cylinders should be pretty close to one another, one or two that are much lower can signal a problem.
Old Dec 12, 2008 | 06:52 PM
cacree's Avatar
cacree
Okay will do and will post them on Monday. Thanks!
hubcap
Modular V8 (4.6L, 5.4L)
Feb 19, 2020 05:05 PM
craziejoker
Jan 16, 2014 05:32 PM
fhafer
Oct 25, 2013 01:30 PM
kingair41
May 21, 2012 08:38 PM
jerkypants
Feb 13, 2012 07:19 PM
