icp repair
icp repair
Mechanic called, finished putting in my I c p sensor, it seemed o he had it for three days for an easy fix (2005 6.0). He said it is low on oil and smoking something awful. It was running fine untill the no start, and never smoked a day in its life. What coulf he have done to it? I know he started somehow, cause it was outside and then was inside.
Anything ideas? I know something went wrong.
Boy this doesnt sound Good A simple repair on an ICP sensor on an 05 Is way easy
It probably takes longer to find the right size wrench to get it off than it is to Change the sensor
Really easy on an 05 we could have walked you threw it
Pretty Odd that it would have a majoir Failure just from that
So the mechanic said that the oiil was low so is the Oil in the coolant bottle?? NOW????
Do you trust this mechanic???
could just be burning off fuel in the system from the no start IDK also might be a good idea to pull the egr vavle out to look for coolant there just thinking out loud
He called me back and said he thinks he stripped the threads. The stripped threads must be on the black rectangular box it screws into. I did trust him, but know I don't know.
When I went down there he was pulling in with it, it wouldn't restart, and the coolant bottle was in ****ed up.it was sticking up, I dont know how he shut the hood. I am thoroughly dissapointed. What is the part the icp screws into?
That sucks he should have to pay for anything messed up period
If the ICP sensor was bad I dont understand why he was messen with the coolant bottle especialy on an 05+
Id say its time for some gauges like a SGII then you could see whats going on with it with all the Help here on FTE you could have changed it
Somethings not right with this I think this guy doesnt do to many 6.0s
It probably has a HPO leak somewhere I would be scared for this guy to fix it he may do more damage than good IDK
What were your symtoms upon taking it there Just a No-Start??????
Sounds like he didn't know the difference in location of the ICP on the early and later trucks, then he went after it like it was under the turbo ..... so he possibly had the FICM out and injector harness pulled aside .... that's why the coolant bottle is moved.
Maybe the problem arose when he went to put that stuff back in, bad connection on one of the injectors, or a bad connection at one of the FICM connectors. Just a thought.
But all the white smoke IDK
Was all the white smoke coming from the Tailpipe or Just leaking out the crooked coolant bottle down onto the exhaust manafold
I bet he sprayed it with starting fluid to get it to start Cause if it still wont start the problem remains
Id say once it runs or whatever Id never go back to that shop if he didnt know enough that the ICP location had changed on an 05+ he doesnt work on them all that much
I wonder if he checked the HPO pressure it was low so he thought Bad ICP when in all reality its got a HPO leak somewhere
With a SGII you would have been able to monitor the HPO and lots of other things . Even if you dont do the wrenching on your truck the SGII would give you a very good Idea what parts the shop should be dealing with
Do you know if it had any codes??
And what was the deciding Factor that pointed to the ICP sensor being bad??
It ran just fine, a few no starts, but come back lateror in the am and it would fire right up. Then the code for fuel level sending unit. Then the no start. He had a computer on it that led him to icp sensor. The smoke was more black. I am thorougjly disgusted, I will get the scanguage or is the ae better?
SGII is a great gauge to keep in the truck you can chheck sensor values
AE is the best thing to test with you can control things like buzz injectors and also do cylinder balance testing and lots more
willamettefarmguy
15
11-30-2016 10:16 AM
