coolant change out
Old Dec 9, 2008 | 01:56 PM
gambling209's Avatar
gambling209
coolant change out
looking to do this. what is the recommended coolant for my 01 7.3. is it the xerox g-05? do you run any additives with it. any special things to do to make sure it is done right?
Old Dec 9, 2008 | 02:01 PM
HKusp's Avatar
HKusp
Some of the best seems to be the Shell Rotella ELC coolant, or one like it. Read this:https://www.ford-trucks.com/forums/4...c-coolant.html
Old Dec 9, 2008 | 02:18 PM
Izzy351's Avatar
Izzy351
You can use G-05 without additives up to 100k. What do you have in your truck now?? The Rotella ELC or FinalCharge is a 300k coolant, which is good stuff for sure. That's what I'll be putting in mine when it's due. There have been lots of threads discussing the flush process -- I can try and find it, if you want. I'm in a class, so I'm kind of tied up. Surfing FTE to keep myself awake... LOL
Old Dec 9, 2008 | 02:48 PM
Ponyboychris's Avatar
Ponyboychris
Stolen from another 7.3 site but a good step-by-step:
Get ready.
Go to the store and buy 4 gallons of Zerex G-05 gold antifreeze. Go to Wal-mart and buy 20 gallons of distilled water. Go to my auto parts store and buy a coolant filter replacement element for my aftermarket coolant filter system.
If you don’t already have a cooling system flush kit installed, then go to almost any auto parts store that sells Prestone antifreeze and buy a Prestone flush kit. It’s only a few bucks.
If you haven’t already done it, then you’ll also need a new lower and upper radiator hose and a new thermostat. I did that last time, so I won’t do it again yet.
Tools needed include:
- a large pair of “water pump” pliers for removing the upper radiator hose from the thermostat housing. Those pliers are also called "channel-lock" pliers
- a 3/8th inch rachet with 6” plus 3” extension and an 8mm socket to remove the bolts that hold down the thermostat housing,
- a 5-gallon bucket. If the bucket won’t fit under the radiator drain valve and still have room to open and close the valve, then I’ll also need a pair of ramps to raise the front of the truck a bit.
- a kiddie wading pool about 4 or 5 feet diameter and several inches deep.
- something to dip the water out of the kiddie pool and into the 5-gallon bucket. Maybe a 2-quart saucepan?
- a garden hose that will reach from the faucet into the engine compartment of your truck.
- a clear glass canning jar or plain water glass
- a funnel for pouring gallon jugs of liquid onto the Degas bottle.
-If you must haul the used antifreeze to somewhere other than your bathroom to pour it down the toilet, then you'll need a bunch of empty one-gallon milk jugs or water jugs. (Most jurisdictions allow you to pour used coolant down the toilet.)
Drain
Remove the radiator cap from the Degas bottle.
Drain the radiator into the 5-gallon bucket. Stop it from draining at about 3 or four gallons and empty the bucket by properly disposing of the used antifreeze. Then finish draining the radiator. You should get a total of about 5 gallons out of the radiator drain valve.
If you have one, remove the coolant filter element and dispose of it. If you have a shut-off valve on the coolant line, be sure you leave it open so the lines will flush.
Place the kiddie pool under the front of the truck to catch any leaks and drains.
Remove the upper radiator hose from the thermostat housing (this is a heck of a lot easier said than done!). Remove the thermostat housing. Remove the thermostat. Install the thermostat housing without the thermostat. Install the upper radiator hose.
Install the flush “T” on a heater hose. Connect the garden hose to the “T”.
Flush with tap water.
Turn on the water to a low pressure but enough to run into the system faster than it drains out of the radiator drain valve. Too much pressure will damage the heater core. The water will begin draining from the radiator drain valve.
Watch the Degas bottle, and as soon as you see water begin to rise into the Degas bottle, crank the engine. Let the engine idle for a couple of minutes, then kill the engine. Turn off the water. Let the water drain from the radiator drain valve (and maybe some from the coolant filter base).
Dispose of the water in your catch basin (kiddie pool) and get ready for another cycle.
Turn on the water and wait until the water begins to rise in the Degas bottle, then crank the engine. Let the engine idle for a couple of minutes, then kill the engine. Turn off the water. Let the water drain from the radiator drain valve. As the water drains, catch a glassful and notice the color. If there is even a hint of color in the drain water, we need to flush it again with tap water from the garden hose.
Dispose of the water in your catch basin and get ready for another cycle.
You may need three or 4 cycles before the drain water is clear water with no hint of color from the old antifreeze. After your drain water is nothing but clear water, then replace the kiddie pool with the 5-gallon bucket. Disconnect the garden hose and close the flush ”T”. Close the radiator drain valve. If you have an aftermarket coolant filter, install the new coolant filter element and connct the lines to the filter base. (If you don't have a coolant filter, now is an excellent time to install one. )
Flush with distilled water
Pour in 4.5 gallons of distilled water. Crank the engine and let it idle for a couple of minutes. Kill the engine and drain the radiator. Don’t try to rush the draining. It will take awhile to drain out all 4.5 gallons you just poured in.
Repeat that last step three more times – until you have poured in, circulated, and drained out a total of 18 gallons of distilled water.
Button it up.
Replace the thermostat, the thermostat housing, and the upper radiator hose. Be sure the thermostat housing bolts are good and snug, and the hose clamp is moved down to it’s original position on the hose. If you dropped a bolt and it disappeared into the bowels of the area around the water pump, then go to the Ford house and buy another one. Expect to pay more than $5 each for those 15 cent bolts. (Don’t ask how I know this. )
Filler up.
Pour in 4 gallons of gold antifreeze. Top off with distilled water. I just barely got the 20th gallon of distilled water open when mine was full. But after driving it to town a couple of times, some of the air bubbled out and it took a bit more. Hang on to that last partial gallon of distilled water for later additions.
Finally, that job is done. And it should now be good for at least 50,000 more miles with no coolant maintenance.
By using all 4 gallons of antifreeze, my concentration is about 57 percent antifreeze. That’s good enough for some very cold country.
Options I didn’t use.
If you remove both block plugs as well as draining the radiator, the tap water flush should not require as many cycles to get all the color out of the system. But that is a PITA, so I didn’t even think about it.
If you replace gold coolant with gold coolant, you would do it the same exact way - except your drain water will have a gold or tan/brown tint instead of a green tint.
If you replace green coolant with green coolant, you would also do it the same way, except at the very end you would add 3 pints of supplemental coolant additive (SCA) right after you poured in the antifreeze - before you topped off with distilled water.
If you want the 50/50 mixture of antifreeze and distilled water most experts recommend, then pour in only 3.5 gallons of antifreeze instead of all 4 gallons. Then fill the half-empty gallon jug of a left-over antifreeze with distilled water, and mark the jug "50/50". Then you’ll have topping-off mixture for future use.
If you replace the top radiator hose, be sure the new one is for trucks with two alternators. Then it will go around the fan belt instead of through it.
Old Dec 10, 2008 | 05:59 AM
gambling209
thanks
still have stock stuff. only 80k miles and have been using additive.
Old Dec 10, 2008 | 07:10 AM
vettdvr's Avatar
vettdvr
I use Fleet antifreeze for diesel,,
Old Dec 10, 2008 | 07:46 AM
03_PSD's Avatar
03_PSD
Great post Chris, saving for future use!
Old Dec 10, 2008 | 07:57 AM
mueckster's Avatar
mueckster
Change to ELC
I did a slight variation of the flush & change instructions. I replaced my W/P(rubber gasket was leaking behind it) during the Thanksgiving holidays and installed Peak Final Charge & new radiator hoses. I ran the engine to operating temp and then drained the radiator. By this time, the engine had cooled down some and I removed the block drains. I have a large drain pan made from a Merc Cougar gas tank that fits under the entire engine area, so that I can remove both plugs at the same time. I removed the heater hose from the top of the W/P and turned it up and stuck a funnel into it. I poured distilled water thru this hose to backflush the heater core and get the old coolant out. Did this with a couple of gallons. The water drained back out thru block on the pass side drain. I then poured more distilled water in to the degas bottle, which went thru the W/P and eng oil cooler and back out the driver's side drain. All clear now. I put the plugs back in a proceeded with the W/P change. I changed the hoses and coolant filter, then added 4 gals of Final Charge ELC and topped off with distilled water. I added about a half gal of distilled water over the next few days as the air bled out and the level stabilized. It's all good now and I don't have worry about SCA's and coolant changes for a long time. As a note: The cooling system was pretty clean from previous flushing and coolant changes. If this is the first change, it may require more flushing cycles before the distilled water flush and adding the coolant.
Sorry for being so long winded.
Avanti
Escape & Escape Hybrid
Jul 31, 2013 09:40 AM
Coondawg
2004 - 2008 F150
Dec 9, 2012 09:31 AM
amd_038
Aug 20, 2011 08:03 PM
koabob
Jul 17, 2009 12:58 AM
01' Super Crew
1997 - 2003 F150
Mar 6, 2003 09:26 PM
