2005 F-150 coolant change
Hey fellas. I was going to start getting the stuff together to do a coolant change and noticed that the coolant is a yellow color and none of the parts houses have that particular coolant. They said the universal 50/50 blend is fine but the owners manual says to use the yellow stuff.
Is there an aftermarket coolant I can use that will replace the factory stuff without any issues?
Also, how many gallons will I need?
Quick search shows this info;
How-To Matthew: Types of Coolant and Antifreeze
http://www.recycool.net/index.php?op...acts&Itemid=10
I guess the fine print on the jugs does matter... Although the Prestone site does say their product is compatable with any fluid type.
Resendiz
41
10-21-2016 12:46 AM
