Won't shift to park
Old Nov 27, 2008 | 06:45 PM
Totally Tuna's Avatar
Totally Tuna
Won't shift to park
More often than not it won't shift into park. It is getting worse and I anticipate soon it will not ever go into park. It seems to be shifter related rather than transmision related. I have to shut the truck down in reverse to get my key out... and I have to start it in Neutral since it wont start in a gear. Anyone have any ideas on what could be causing this? I'd like to fix this myself if it is easy. Truck is a '92 w/ 7.3l.
Old Nov 27, 2008 | 09:14 PM
EMD_DRIVER's Avatar
EMD_DRIVER
I would check where the shifter cable is mounted on the tranny. It may just need some adjustment.
Old Nov 27, 2008 | 10:22 PM
PLC7.3's Avatar
PLC7.3
Make sure the manual lever position sensor is set correctly........ then do the cable adjustments......... posted before I will PM it to you....
Old Nov 30, 2008 | 02:44 AM
ford trans tech's Avatar
ford trans tech
at the trans look behind the shift lever for a rsmall rock lodged in it preventing it from going to park , but you shouldnt be able to remove the key in reverse
also does it have a shift cable at the trans or shift rods and a bell crank
Joejoecat
1983 - 2012 Ranger & B-Series
Jun 22, 2011 07:52 PM
Blacknav
Jan 2, 2011 11:03 AM
denvertruckman
Apr 26, 2009 08:20 AM
smccatv
Jun 23, 2008 06:13 PM
fludoc
May 29, 2008 03:08 PM
