Shifter won't move
Old May 29, 2008 | 08:41 AM
fludoc's Avatar
fludoc
Shifter won't move
94 E150 van
When we start the van and go to put it in gear the shifter will not move out of park. This is a new development that started with no warning, one day it was fine, the next it wouldn't shift. I have found that if I turn the key in the ignition just a lilttle, like I would be starting it again, that the shifter will release and work fine. Until I put it in park again. Then I'm back to square one. Obviously this is not a good situation. Anybody have any ideas on what caused this issue?? Thanks.
Old May 29, 2008 | 08:47 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Usually it is either a failure of the brake light switch or the solenoid that releases the shifter when the brake lights are on. Do your brake lights work? If so, then it's probably the solenoid.
Old May 29, 2008 | 08:53 AM
fludoc's Avatar
fludoc
Thanks Mark. I will check the brake lights and see. If they're ok where is this solenoid that would need changed, is it difficult to get to?
Old May 29, 2008 | 09:03 AM
fludoc's Avatar
fludoc
Just went and checked and brake lights are not working. Where would this brake light switch be located? Thanks again. It's great having someone to ask who actually knows something!!
Old May 29, 2008 | 01:39 PM
rclarke's Avatar
rclarke
The brake light switch is on the pedal/pushrod connection. Often one of the wires might be broken at the switch connection. The circuit also is fused.
Old May 29, 2008 | 03:08 PM
fludoc's Avatar
fludoc
ok, thanks. I searched some other posts and found more info. The 15 amp fuse was blown. I replaced it and blew the new one. Then I reached down and wiggled the wires on the switch, just for chuckles, and put in another fuse and now it works! Obviously a bad connection in the switch which I'll look into next. Thanks again.
seattle smitty
16
Sep 30, 2015 12:12 PM
Jose A.
Aerostar
Apr 4, 2015 06:42 PM
oct7brian
Jan 13, 2015 05:04 PM
tjc transport
52
Dec 23, 2014 06:17 PM
teamlx88
Jul 20, 2014 01:49 PM
