Early 99 + AE = NO Cylinder Rotation Values?
Hi all,
I have been chasing down a power / rough running issue and wanted to do a cylinder rotational value comparison. Hooked up my brand new AE and - Nothing - i do not have the Cyl Rot Values listed in the drop down box...
Talked to AE they say:
"It's not an issue with the software. We do support the Cylinder 1 Change
Rotational Velocity or PERDELS. It's in our software for any model 99-04
7.3L. Check your truck is really a 99 and not a 98. Prior to 99 there is no
such thing as PERDELs. You can't fool the scan tool into giving PIDs in this
case. If the model year selection is correct then retry your connection. I
find it odd that only the different PIDs from 98 and 99 are missing.
Something is wrong with the ECM."
Does any one here have AE and an early 99 F250? Are you able to view this data?
Aslo i have heard mention about a recall to flash upgrade the older PCM...any one have info on this...
If not i guess i will start swapping injectors around to see if the Weak sounding #5 and the Failed CCT #8 is injector problem or ather more serious problem...
Thank you,
</pre>
Thank you,
</pre>
I think it says something like Change Rotational Velocity Cylinder X. If you can't find it on the drop down menu in the live data tab, try pretending your truck is a 2000 to see if you can find it.
I know I've checked it on a 99.5 model at work (selected 99 model year) but that was on an older version of AE. I've got the update version now. If you still aren't having any luck, I can check my new version on the 99 next week to see if I have the same problem.
Also, make sure the engine is warmed up before taking these readings. The PCM won't register rotational velocity % until 160 or 170 deg.
AE makes it sound like it does have to do with the info on your PCM...To me the AE log looks like it queries the PCM and then gets a list of "sensors" that it has available.
I will keep digging into this and find out...I have a laundry list of things to do over the long weekend and now one of them is to take a look at my PCM and find out about the possibility of upgrading it with a new Flash.
Anyways, I will keep you all posted
This is good info Mike. I can't find it when I am scanning my early 99 but ran across it while doing a friends late 99. I will have to look again. I also have the XLE4.
Dang it- I meant to look at my pcm when i was working on it yesterday!!!
I will have to take a look in the morning!!!
Makes me feel better knowing that there are others with early 99's that cant see the PIDs
I need to find more info on the pcm - maybe talk to Jody too - since I have already asked for a DP tuner for Xmas
Robin - Wahts the build date on your truck? I just noticed your sig 99.25?? Mine is Feb98
Oh I see - Got the PMS bad huh?
Chris - BTW i tried to connect as a 2000 model that didnt work either...
Hopefully i will not even need to worry about this test after replacing the inj on monday...Please let the UPS truck come early!!!
Also ive been looking at Tony's site for his tunes...might have to take a lil road trip and have him doctor my PCM
(another reason why TX is an awesome place to live!!!)
I will keep you posted...
on
type in truck info with the VIN ..this is what i had to do to get mine to work..but i also got mine 3 years ago..it seems the early 99 is vin specific because of so many changes during that year..my truck is a early 99 a 99.5 01 truck now..i have to use the 01 on AE to run test..i have the PMT1 PCM out of one..
JT250
10-24-2012 12:25 PM
