Early 99 + AE = NO Cylinder Rotation Values?
Old 11-25-2008, 08:09 PM
GrizzlyPiet's Avatar
GrizzlyPiet
GrizzlyPiet is offline
Hi all,
I have been chasing down a power / rough running issue and wanted to do a cylinder rotational value comparison. Hooked up my brand new AE and - Nothing - i do not have the Cyl Rot Values listed in the drop down box...
Talked to AE they say:
"It's not an issue with the software. We do support the Cylinder 1 Change
Rotational Velocity or PERDELS. It's in our software for any model 99-04
7.3L. Check your truck is really a 99 and not a 98. Prior to 99 there is no
such thing as PERDELs. You can't fool the scan tool into giving PIDs in this
case. If the model year selection is correct then retry your connection. I
find it odd that only the different PIDs from 98 and 99 are missing.
Something is wrong with the ECM."
Does any one here have AE and an early 99 F250? Are you able to view this data?
Aslo i have heard mention about a recall to flash upgrade the older PCM...any one have info on this...
If not i guess i will start swapping injectors around to see if the Weak sounding #5 and the Failed CCT #8 is injector problem or ather more serious problem...
Thank you,
</pre>
Old 11-25-2008, 08:17 PM
F350-6's Avatar
F350-6
F350-6 is offline
I think it says something like Change Rotational Velocity Cylinder X. If you can't find it on the drop down menu in the live data tab, try pretending your truck is a 2000 to see if you can find it.
I know I've checked it on a 99.5 model at work (selected 99 model year) but that was on an older version of AE. I've got the update version now. If you still aren't having any luck, I can check my new version on the 99 next week to see if I have the same problem.
Also, make sure the engine is warmed up before taking these readings. The PCM won't register rotational velocity % until 160 or 170 deg.
Old 11-25-2008, 08:27 PM
GrizzlyPiet
Thanks Chris,
I havent thought about trying to connect as a 2000 truck. I will try that in the morning after my drive to work...
BTW i am hooked to ae...i have spent the past 2 days just driving around and recording different sensor data....
Thanks for pointing me in that direction.
Old 11-25-2008, 08:44 PM
F350-6's Avatar
F350-6
F350-6 is offline
No problem. It's definitely a neat little toy if you can understand what half all that info is. Let me know if you don't get anywhere. I'm out of town right now, but I can hood mine up to the 99 on Monday if you can't figure anything out before then.
Old 11-25-2008, 09:29 PM
cangim's Avatar
cangim
cangim is offline
Mine is a pre 99 and I was able to read mine with out any problem. PCM code is XLE4 if that matters.
Old 11-26-2008, 09:43 AM
superduty4x4's Avatar
superduty4x4
superduty4x4 is offline
Does AE rely on PCM code for doing its tests? I have an early bird with an 01 PCM so I should be fine, but just curious.
Old 11-26-2008, 06:29 PM
GrizzlyPiet
AE makes it sound like it does have to do with the info on your PCM...To me the AE log looks like it queries the PCM and then gets a list of "sensors" that it has available.
I will keep digging into this and find out...I have a laundry list of things to do over the long weekend and now one of them is to take a look at my PCM and find out about the possibility of upgrading it with a new Flash.
Anyways, I will keep you all posted
Old 11-29-2008, 12:20 PM
PaysonPSD's Avatar
PaysonPSD
PaysonPSD is offline
This is good info Mike. I can't find it when I am scanning my early 99 but ran across it while doing a friends late 99. I will have to look again. I also have the XLE4.
Old 11-29-2008, 06:53 PM
GrizzlyPiet
Dang it- I meant to look at my pcm when i was working on it yesterday!!!
I will have to take a look in the morning!!!
Makes me feel better knowing that there are others with early 99's that cant see the PIDs
I need to find more info on the pcm - maybe talk to Jody too - since I have already asked for a DP tuner for Xmas
Robin - Wahts the build date on your truck? I just noticed your sig 99.25?? Mine is Feb98
Old 11-29-2008, 07:26 PM
F350-6's Avatar
F350-6
F350-6 is offline
Robin has started changing some parts. He's on his way to making his a 99.5, or late model 99.
Old 11-29-2008, 08:08 PM
GrizzlyPiet
Oh I see - Got the PMS bad huh?
Chris - BTW i tried to connect as a 2000 model that didnt work either...
Hopefully i will not even need to worry about this test after replacing the inj on monday...Please let the UPS truck come early!!!
Also ive been looking at Tony's site for his tunes...might have to take a lil road trip and have him doctor my PCM
(another reason why TX is an awesome place to live!!!)
I will keep you posted...
Old 11-29-2008, 08:32 PM
F350-6's Avatar
F350-6
F350-6 is offline
You might give him a call. It seems like he's got a few PCM's laying around. Of course I don't know if you would need an updated PCM or if his chip does enough updating on it's own.
Old 11-30-2008, 12:06 PM
GrizzlyPiet
Thats kinda waht im wondering...
Once i get my injector issues fixed and the coolant res replaced...then i will take some time to talk to him about getting my baby to pull a lil better
Old 11-30-2008, 04:36 PM
ron's power stroke's Avatar
ron's power stroke
ron's power stroke is offline
type in truck info with the VIN ..this is what i had to do to get mine to work..but i also got mine 3 years ago..it seems the early 99 is vin specific because of so many changes during that year..my truck is a early 99 a 99.5 01 truck now..i have to use the 01 on AE to run test..i have the PMT1 PCM out of one..
Old 11-30-2008, 06:55 PM
PaysonPSD's Avatar
PaysonPSD
Ron,
Thanks, if I can't find it I will try this.
Tugly
30
07-24-2023 01:59 PM
akmikek
21
04-10-2015 05:19 PM
JT250
10-24-2012 12:25 PM
Quick Reply: Early 99 + AE = NO Cylinder Rotation Values?
