AE and PERDEL Readings
I have the latest edition of Auto Enginuity and was wondering if im missing something with regards to Cylinder Change Rotational Velocity test? I set up all 8 cylinders ob the program and they never change from 0.00. Even if im driving around or sitting still at idle. Is there a special thing that has to be done to get it to show up?
I have tried to do it in stock setting. I'm not sure on the idle speed, just above 100-150 rpms? I am going to try again tomorrow when the truck is warmed up after work. Cylinders 2 and 8 show up in the cct but 1 and 8 show up on the buzz test codes. It seems to run alright but keeps pulling the codes.
This morning I went out and the truck started right up and had a decent idle. I ran buzz test which failed #1 and # 8 and I shut off see light. I drove to work just missing a little. Cyl #8 and Cyl #2 fail CCT. I am hoping when I replace the #8 injector the light will stop coming on. Do you think that its the cyl #8 injector that is causing the light? Failed CCT and buzz on #8? Tonight I will try perdel again.
Here are your trouble codes:
P1316 Injector Circuit/IDM Codes Detected
P1268 High to Low Side Short - Cylinder 8
P1271 High to Low Side Open - Cylinder 1
How did the injectors sound during the buzz test? Can you give us an audio or video file to look at? Did 1 and 8 sound noticeably different than the others?
Here is a diagram of the IDM & injector wiring:
The injectors are grouped into two banks of four injectors each -Drivers side & passenger side. Each bank/side shares a common power feed which is generated by the IDM. The voltage supplied to the injectors is 115 volts DC and is only activated when one of the injectors is firing.
The injectors have 8 individual ground circuits. An injection event occurs when the IDM supplies power to the bank for the injector to be fired while simultaneously grounding the desired injector’s ground circuit.
So, I would check your wiring (which is easy to do) from the 42 pin connector to the injectors & back before pulling injectors. The codes are pointing to a short in #8 on the drivers side and an open circuit to #1 on the passenger side. This could be a wiring/electrical problem.
To go into more detail GB has a great site:
» Ford 7.3L Powerstroke IDM Operation
Here's something that Rich(Tugly) & Pete(F250_) put together to help troubleshoot the IDM & wiring. Basically you need to:
Clear out the trouble codes
Run a KOEO test and recheck for codes
Injector buzz test - see if any sound different from the rest.
Unplug the 42 pin connector on the drivers side valve cover
Ohm out injectors at the 42 pin connector, this will test the wiring from the 42 pin connector to the injectors and back (including the UVC wiring harness). Ohm test between the drivers side + supply & the even number injectors pins in the pic below. Then ohm test the passenger side + supply and the odd number injector pins in the pic below.
