Transmission Fluid Change
Old Nov 24, 2008 | 05:16 PM
Docdor's Avatar
Docdor
I have a 2004 F-350 SC Diesel. Getting close to 60,000 miles and I started checking owners manual for maintaince. It spelled out to change tranny fluid and external filter(roll of paper) at 60,000 miles. Question is when does the internal filter get changed.
Thanks
Old Nov 24, 2008 | 05:38 PM
RoyC's Avatar
RoyC
It is never mentioned in my maintenance schedule, and I understand it is not a filter, rather a screen.
RoyC
Old Nov 25, 2008 | 01:53 AM
cartmanea's Avatar
cartmanea
I changed my internal, but only because it had 74k when I got it and I had no idea if or when it had been serviced. My dad had his internal filter changed with a fluid flush at 55k and the internal screen was clean as can be. I'd say don't worry about it unless you've ever had tranny problems.
Old Nov 25, 2008 | 06:44 AM
m350's Avatar
m350
I did my 06' F-350 six-O,TS tranny at 33k,,pull the drain plug,,drop the pan,,was nice and clean inside, new screen and the inline filter,,,the screen is kinda hard to see inside it,,,more like a tube(unless u cut it open),,but the inline filter,,was rather dark,,so It does work.
I beleive I purchased 14qts SP,,I think it took about 9 qts to change it,,by dropping the pan,,I would have to check my records though.
Old Nov 25, 2008 | 08:31 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
The internal filter needs to be changed at a rebuild. It really doesn't need to be changed before that.
Old Nov 25, 2008 | 10:40 AM
cartmanea's Avatar
cartmanea
Mine took 9 quarts with a pan drop as well. I plan to drain fluid and refill without a pan drop in another 10k.
Old Nov 27, 2008 | 07:10 AM
D8chumley's Avatar
D8chumley
Resident smarta$$
X2 on the 9 qts. Interesting on the internal filter. I also changed mine as I didn't know if/when it had been changed, I think I'll do the same as Cartmanea said- change external filter and drain/ refill in 10k.
Old Nov 27, 2008 | 09:46 AM
69cj's Avatar
69cj
If I recall correctly, the manual calls for external filter at 15,000 and tranny flush at 30,000. I have been doing the external filter every 10,000. Cheap ins. even though the filter is not cheap.
Old Nov 27, 2008 | 11:25 AM
Docdor's Avatar
Docdor
Ford Parts and Motorcraft Parts at Discount Prices Ford Think Parts Guys check out this site for discount parts
DSMMH
Aug 14, 2012 12:29 PM
Bbasso
Modular V10 (6.8l)
Nov 5, 2011 06:17 PM
Bbasso
Nov 4, 2011 10:38 PM
cads03
Jan 13, 2006 10:36 PM
sdilling
Nov 24, 2003 08:54 AM
