Cab Insulation
Old Nov 30, 2008 | 08:57 PM
mytbtruck's Avatar
mytbtruck
Originally Posted by 53pickemuptruck
Is that the framework for your seat mount that the fuse block is mounted in? I like the look of it. Got my wheels turning a little better. Got any other shots of the whole thing?
That is the frame for the seat. I can get some more pictures if needed. This is the frames when we first started them. The battery box was welded together and welded to the passenger frame.They fit the seats good and all that wiring under there is out of the way.
Old Nov 30, 2008 | 09:29 PM
Kusto's Avatar
Kusto
Very nice work along with some great ingenuity. Keep up the good work and I can't wait to see the final product. What is the front suspension out of?
Old Dec 1, 2008 | 05:04 PM
mytbtruck's Avatar
mytbtruck
That suspension is from a 95 T-bird LX. Both front and rear suspensions are from the same car. I took a lot of fabricating but was well worth it.
Old Dec 1, 2008 | 11:36 PM
Kusto's Avatar
Kusto
I see NAPA has insulation (similar to Dynamat) 2 29"x29" sheets for $45.00, would this stuff be any good?
Old Dec 2, 2008 | 02:31 PM
Old F1's Avatar
Old F1
A few years ago I got some from napa, kina black rubberish stuff with a blue wax paper pull off for the self adhesive (Body Pro?). It worked OK but not as good as I would expect the real stuff to work. The old “you get what you pay for” story. When I used the napa product in the inside of the roof the glue eventually give way and the pieces fell down onto the headliner, should have used extra glue.
Old Dec 2, 2008 | 04:16 PM
jniolon's Avatar
jniolon
old and in the way
Originally Posted by mytbtruck
I am running a 95 4.6L with 4R70W transmission. That ECM is for the engine and transmission and all that wiring is required for that setup. That control panel has all the connections the 98 T-bird had. It is a Telorvek wire kit from THE DETAIL ZONE. It was a little pricey but all new connectors and wire makes it worth while for dependability, or that is how I look at it. I want to drive this truck anywhere without worrying if it will make it.
MAN...
is that an engine turned firewall cover.... closeup please ... I love that look
John
Old Dec 2, 2008 | 08:05 PM
mytbtruck's Avatar
mytbtruck
Originally Posted by jniolon
MAN...
John
That firewall is a piece of steel deck plate. I sand blasted it, primed it and used semi gloss auto enamel paint with hardner. I will send a picture of the inside also.
Old Dec 2, 2008 | 08:16 PM
mytbtruck's Avatar
mytbtruck
MAN...
John
This is the inside with insulation and carpet installed. Fittings showing are a/c and heater hose connectors. I did not need the hump to clear engine and transmission so I made the floor flat. Sure gives me a bunch more room. Most of us driving are 6 ft or taller and the extra room helps.
Old Dec 3, 2008 | 04:02 PM
BACAGrizz's Avatar
BACAGrizz
Very nice work. I appreciate your attention to details.
I only hope mine turns out as nice.
Old Dec 3, 2008 | 05:36 PM
doug51f1's Avatar
doug51f1
Man that is some nice work!
Super Econoline
15
Oct 1, 2013 05:47 AM
rmalottwtes30
Dec 15, 2011 02:43 PM
Speedjester
Aug 26, 2010 10:18 PM
OneTon4Fun
Feb 22, 2008 11:16 AM
fireball69
1997 - 2003 F150
Jul 21, 2004 12:11 AM
