Number Dummy can you help again?
Old Dec 3, 2008 | 04:22 AM
turnrjr's Avatar
turnrjr
Having trouble identifying a Spacer Ring that goes on the pilot journal of the output shaft on my 53, 3 speed, overdrive, light duty transmission. Painted on the case 3TA. My illustration calls it a 7063. Going to the parts list though, it doesn't show for the remaining numbers. The pilot journal OD that it goes on is .83"
Thank you
Bob
Old Dec 3, 2008 | 05:22 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Thank you
Bob
Where did you find that basic p/n of 7063?
It's not shown in the pic of the transmission or the O/D.
The snap ring is basic number 7064, that is all I see.
Old Dec 3, 2008 | 04:06 PM
turnrjr's Avatar
turnrjr
Form FD-9465 (mine is on CD) Illustration Section 70, page 193.
Old Dec 3, 2008 | 04:56 PM
NumberDummy
I have the books, but they're the same issue = printed 1964.
B-7063 .. "Spacer, Output Shaft Pilot Bearing" is shown in parts list #1.
But...you have a 1953 w/O/D, and that transmission is parts list #14 (Text-page 329-last entry).
7063 is not listed.
The same trans was used in 1954. 1955/56 O/D trans is parts list #27. Again, there is no listing for that spacer.
Not listed = not used.
Parts catalog illustrations are generalized because the only purpose is for part number basic number info.
One year might use a particular part, the next year it's no longer necessary.
EDIT: I also have the 1953 Ford and Mercury Truck Chassis Parts Catalog, printed May 1953.
No 7063 listed for the O/D transmission.
Old Dec 3, 2008 | 06:14 PM
turnrjr's Avatar
turnrjr
Bill thanks for your time. When I opened mine up, there was a flat, shim type washer where the 7061 spacer is suppose to be. It is buggered up so I wanted to replace it. I've been getting my parts from Mac Vanpelt and he came to the same conclusion as you after trying the B7063 (too small diameter) I will put it back together without any. Thanks again
Bob
Ninetynine7.3
Mar 2, 2015 09:37 AM
sonny1965
Jun 5, 2014 06:48 AM
1972RedNeck
Ford vs The Competition
Nov 16, 2013 10:45 PM
bob arrington
Dec 17, 2003 08:55 PM
bob-63-292
Nov 16, 2003 09:41 PM
