2004 fx4 tapping noise in motor after warm
Old 11-05-2008, 04:38 PM
mirage5058's Avatar
mirage5058
mirage5058 is offline
I have a 2004 ford f150 fx4 had it to garage many times they say its nothing but when im driving after its warmed up,it makes a metalic tapping noise even when idling you can hear it,anyone else have same problem,any help will be greatly appreciated,thanks
Old 11-05-2008, 06:30 PM
mericanwit's Avatar
mericanwit
mericanwit is offline
oh yeah, it'll get worse and sound like a diesel... there's probably a tsb on it... I have an 04 fx 150 and nothing but issues...
Old 11-05-2008, 11:56 PM
mirage5058's Avatar
mirage5058
tapping noise
This truck only has 35000 miles on it any idea of a fix or what exactly it is
Old 11-06-2008, 05:50 AM
crabhab's Avatar
crabhab
crabhab is offline
Lifters or a cam phaser
Old 11-06-2008, 07:34 AM
Fishin76's Avatar
Fishin76
Fishin76 is offline
well, since there are no lifters in a 5.4L. (overhead cam engine), the likely suspect is the cam phaser. Just guessing, probably louder on the passengers side, right?
Less likely, is a mis-aligned rocker. Either way, your looking at $$$$ to replace the rocker or phasers. It probably will cure the problem for a little while, but it will come back.
Lots of threads on this 'problem', i say that, because ford does not see it as a problem. they will tell you that it's normal. For the most part, it seems to be. My 04 XLT 5.4l has been doing the entire time I have owned it (since 66K). Now have 97k on it. 5w30 may quite it down a little. I had to add oil to mine at 3k recently, no 5w20, so I had to use 10w30. Wow, did that quite it down. just one quart of it though.
No power loss noticed because of the problem, just a louder engine, and other posters are correct, it does end up sounding like a deisel.
Old 11-06-2008, 07:36 AM
Fishin76's Avatar
Fishin76
Fishin76 is offline
Since I don't see anybody that has said it yet, Welcome To FTE!!!
Old 11-06-2008, 04:46 PM
mirage5058's Avatar
mirage5058
Ford tapping noise
Thanks for your replies they have been a big help,Also thanks for the welcome post.
Old 11-06-2008, 05:16 PM
boots6868's Avatar
boots6868
boots6868 is offline
My o4 fx4 5.4 did the same thing. more noticible along side a building. I always used 5w20 synthetics mine started around 40,000 miles I traded it on 08 super duty w5.4 never caused me any problems i was told by the shop it was cam phasers. new truck has 10,000 on it now and quiet for how long?
as far the 5.4 being problematic i wouldnt say that. my 5.4 convinced me enough to get it in my new truck. spark plugs are the biggest issue and their not really a problem if you approach it right.
muddhogg
2004 - 2008 F150
04-21-2013 07:59 AM
powerstroker100
04-04-2010 05:25 PM
DRM2004
2004 - 2008 F150
01-29-2006 07:38 AM
Quick Reply: 2004 fx4 tapping noise in motor after warm
