Sponsored by: Real Truck
stuck caliper
Old Nov 3, 2008 | 03:38 PM
ponch37300's Avatar
ponch37300
stuck caliper
I think i have a stuck caliper on my front drivers side, or the bearing is shot. I have been needing to change my pads and rotors for a while now but haven't had the time, powerslots and hawks are sitting in the garage. There is a grinding noise coming from the wheel and it brakes funny, i was in the home depot parking lot the other day and it wouldn't roll forward in gear, like the brakes were stuck on. I'm going to change my pads/rotors tonight. Is there anything i should look for with a stuck caliper/bad bearing? If it turns out to be a stuck caliper can i fix it or do i have to buy a new caliper? Thanks for any info on this.
Old Nov 3, 2008 | 03:48 PM
someday's Avatar
someday
new caliper and/or hose
Old Nov 3, 2008 | 04:43 PM
ReAX's Avatar
ReAX
Depends on why it's sticking. The caliper rides on pins that allow it slide away from the rotor. If the pins are frozen, or nasty the caliper may not be moving evenly and binding up.
Take a look at your brake fluid. If it's green, it's likely the caliper's piston has corrosion on it as well. I am not sure if you can find a caliper rebuild kit, but the piston sleeve could be cleaned up and the seals replaced to bring it back to life. Otherwise, you need to replace the caliper.
Old Nov 3, 2008 | 05:14 PM
WestxSRT10's Avatar
WestxSRT10
How many miles are on the truck...i bet over 60K? How many times have you flushed the brake fluid?
Old Nov 3, 2008 | 07:52 PM
dstig1's Avatar
dstig1
Wow - you mean somebody other then ME actually flushes brake fluid from their vehicles? Good car maintenance - It's a rare disease, apparently.
Old Nov 4, 2008 | 12:02 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
Also, the pads have a tendency to actually corrode to the caliper bracket - mine did this and caused all sorts of weird braking problems until I took it apart and found out that one pad on each side had rotted to the caliper bracket.
Time to do the brakes and see what's up, and how they act after swapping everything out and cleaning everything up.
If the caliper pistons are seizing up in the bores, there is no repair option but replace the entire caliper. BE CAREFUL - if you get too much air into the system, or let the master run dry, the ABS valve unit will need to be bled, which requires someone with a good scan/diag tool to exercise the valves in the ABS unit and bleed at the same time.
Old Nov 4, 2008 | 03:02 PM
AllAboutDaZ's Avatar
AllAboutDaZ
mine did the same thing on the driver side front and what i did was take it apart clean everything out lube the parts and put it back on and it now runs like champ
Old Nov 4, 2008 | 03:12 PM
husker's Avatar
husker
I did my brakes a month ago and had a seize caliper piston. It would heat up the brake and pull to the left(driver's side). A rebuilt caliper and bracket at NAPA was about $70 plus a deposit, but that was refunded when I brought in the old caliper. Problem solved.
Old Nov 4, 2008 | 03:47 PM
ponch37300's Avatar
ponch37300
Thanks for all the help. I changed the rotors and pads last night and it works like a champ. One of the drivers side pads was wore down pretty good. Is there a sure way to tell if the caliper is sticking? The pistons went in with a c-clamp. Thanks again.
Old Nov 4, 2008 | 04:35 PM
boxcar1974's Avatar
boxcar1974
If only one of the four pads were worn more than others it sounds like a slide pin is siezed. Did you check to see how easily the slide pins moved? You should have taken them apart and used a high temp grease to lube them. That is part of any brake job.
Old Nov 4, 2008 | 08:50 PM
husker's Avatar
husker
x2 on the caliper pins. If you didn't check them, go back and do it and lube them. It isn't tough to do unless you've got one that is stuck good.
Old Nov 4, 2008 | 09:08 PM
dstig1's Avatar
dstig1
Always lube the slide pins when you take the brakes apart. Cheap insurance, and you get a look at them to head off upcoming problems, if there are any. Use a lube rated for brakes (high temp), and don't go overboard or it can blow out the bellows when you reassemble.
-Dave
Old Nov 4, 2008 | 09:18 PM
ReAX's Avatar
ReAX
I would also add, clean out the old as best you can. I wad up a paper towel and twist it in and out until a corner comes out clean. I tried silver nevr-seeze and it didn't work so well. I cleaned it out and replaced it with Green Permatex lube, so far so good.
Old Nov 5, 2008 | 01:30 PM
krewat's Avatar
krewat
Always remember Never-seize or Anti-seize contains metal - it can "gall" and lock stuff up.
It's only recommended to use for keeping fasteners from rotting together.
Old Mar 28, 2009 | 07:39 AM
chey1012's Avatar
chey1012
How do you clean the calipers. A mechanic told me that my truck just needed the calipers cleaned.
Restlesswildman
Jun 18, 2014 07:19 PM
crazyrwe
Nov 5, 2011 07:49 PM
rmalottwtes30
Sep 19, 2010 03:02 PM
61 uni
May 16, 2009 07:53 PM
mybigredford
Jun 12, 2007 04:51 AM
