Sticking caliper?
Old May 15, 2009 | 09:46 PM
61 uni's Avatar
61 uni
Sticking caliper?
Has anyone ever had a caliper stick? I'm still chaseing a bad squeak in my drivers side rear. The pads are new, rotor looks fine and I even pulled the axle to eheck the wheel bearings which were good to. I checked oasis and it said the caliper stuck about 60k ago and they added a friction modifier???? Could the caliper be my problem? It does it sometimes while on the brakes and sometimes around a right hand turn at low speed.
Old May 15, 2009 | 09:57 PM
Donny_D's Avatar
Donny_D
i have the same problem, with my front drivers side really annoying this weekend im gonna change the rotor's on the front, i think i might have one of the U clips on the top of the brake pads that may have fell off when i did the pads last year... that may be the problem we shall find out tomorrow after the ball joint and rotor's are done
not sure about the sticking caliper
Old May 15, 2009 | 10:10 PM
61 uni's Avatar
61 uni
Been there done that. Those clips are a joke.
Old May 16, 2009 | 12:11 AM
Ponyboychris's Avatar
Ponyboychris
Did you check the slide pins? They can freeze in the bores and cause a caliper to hang up.
Old May 16, 2009 | 12:13 AM
Donny_D's Avatar
Donny_D
what are the side pins? you talking about the plungers that press the brake pads to the rotor when you apply the brakes? or are they a dffrent part all together?
Old May 16, 2009 | 01:06 AM
PaysonPSD's Avatar
PaysonPSD
Chris is talking about the caliper slide pins. One on each end of the caliper with the rubber boot.
LINK to Guzzle's Caliper Lube. This is for the front calipers but the rears are basically the same, just smaller. Caliper bolts are 18MM and slide pin bolts are 12MM.
Old May 16, 2009 | 07:53 PM
Excursion4X4's Avatar
Excursion4X4
I did have a caliper sticking, right rear. When I was driving something just didn't "feel" right. I got out and put my hand by each wheel....Bingo rr was hotter than the rest. Replace with rebuilt caliper and have had no problem since.
cstanley44
Sep 3, 2016 11:52 PM
FordFETruck
Jan 10, 2016 03:07 PM
bigtexan99
Oct 24, 2014 01:14 PM
Big.Dave
Apr 5, 2012 11:07 AM
4EXTRDR
May 20, 2011 04:08 PM
