Fuel Additives and how often?
If you don't like the study, then do one yourself.
Quite honestly, his study is repeatable, so you can try it yourself to see if your results are the same or not. Until that time happens, what other "proof" do you see out there that confirms or denies a fuel additive's effectiveness? The only thing I ever see is the manufacture's claims, and that's it. At least this is a third party test.
For example, you have an issue with him testing raw fuel. So what? At least he can get a true baseline (untouched, raw diesel) so that his test can be repeated. If you just get pump diesel fuel from any gas station, then the additives present can be different from one station to the next, making the test invalid and un-repeatable. You see now why he chose the base fuel that he did? There are reasons for his methods that you are ignoring
Ok. What has it really told us besides the lubricity properties of each can of snake oil?
Yes it is repeatable. I don't doubt that one bit. What does that really mean? Brand X snake oil is slipperier than Brand Y? If that is what you are trying to prove, fair enough. Please define "effectiveness". IF all you care about is having a lower lubricity number, fair enough. This is more effective than that. If you care about the engine components, how does this show anything that resembles effectiveness? Now if he could show that using 460 score fuel gives you an average of 50000 miles over score 520, I will be the first to admit you have something. Show me from his data, how it helps reduce my operations cost and by how much.
Fair enough. Is his test representative of the fuel I will get from the pumps? Now if he said that the average fuel score is 550, we might have an issue. But to say that the worst case scenario where no additive is added to raw ULSD, is going to be the case every time I fuel up, that is a stretch. Everybody and their brother will accept that raw ULSD has too little lubricity for what we are doing. Nobody has really established what the point of deminishing returns is, AFAIK. Would it be 550? 450? 220? 500? What I see is someone trying to instill fear.
Personally, I use an additive. It makes me feel better, and peace of mind has to be worth something. Of course it doesn't hurt that I can still get 20+ mpg (empty) with my stock injectors that have over 270,000 miles on them.
As long as we're talking about injector life, I'd like to remind everyone that the fuel delivery portion is only half the injector. Since oil is the other half, observing proper oil change intervals is 10 times more important than using a fuel additive in my opinion.
Most manufactures of any type of additive, be it oil additives or fuel additives, often make huge claims that they cannot back up. In this case, he tested the claim of increased lubricity. Does every single additive increase lubricity? According to the results, no. For many people though, they believe that any additive can and will add lubricity to the fuel. By looking at the study that Spicer did, you can make a more educated decision about what you put in your tank.
He bases his recommendations off of industry standards. That's all the data he has to use, so that is all he is able to go by. Is there a perfect wear standard? Is there the perfect amount of lubricity? How much is it going to affect engine life? Who knows. He doesn't try to state that in his study, so it's up to the reader to interpret how comfortable he/she feels about each additive and what they feel is best for their own trucks.
Imagine the amount of time, money, and effort it would take to test hundreds of engines (yes you would need hundreds of them to make any kind of statistical measure valid) and measure longevity based on various fuels and their wear scores. I doubt he has that kind of money to put into a test like that.
Take the study at it's face value. It's a simplistic test designed to challenge a single claim.
here's the link to SW Researches report:
http://www.natbiogroup.com/docs/educ...%20results.pdf
I have argued this point with Aklim plenty of times. I'm done beating the dead horse.......
Joe, Glad you like the Soyshied. I like it also - a great product and helps support the American farmer, glad it is working out for you! Wish it would have been tested with the others on the lubricity study.
Like I said it ain't helped one bit on gas mileage (who knows if it helps my injectors) but I do hammer it alot more often now because it feels better and it wants to do it. I only fill up twice a month so it's no skin off my *** for an extra 72 bucks a year. I'm going to try some soy shield too but other than that will it prolong anything? Who knows and personally I don't care because it did give me a result I'm happy with. Heck in the long run it will probably cost me more because I beat on my truck alot more now but at least I gots me a smile on my face while I'm doin it.
If I knew that and you lived closer I would have given you my Diesetreat 2000 instead of dumping it into the tanks. I must have dumped over a quater gallon into my 44 gallon tank and maybe the rest into my 22 gal car tank. I got fed up of seeing no results and having that gallon jug sit on the table. I think it has that soy shield thingy in it too.
Like I said I could care less if it improves anything numerically. The feeling like it's running smoother and has more powerband in the mid range is all I need to spend six bucks a month extra. Will it prolong my engine life hell if I know the fact that I'm happier with my motor through the next "x" amount of miles however many it may be is good 'nuff for me. The fact that I just went through a weather change could have caused my engine to run better too not the diesel kleen. I won't rule out other factors that just simply don't fit into mathematical equations to produce a constant. So all in all I'm trying it for a while to see if it keeps "feelin" good and if it does then it stays if it goes back to old ways then the kleen goes towards startin my wood for my next briskit smokin
I haven't tried any others because it's just too much hassle to get them. Being in a metropolitan area makes it hard to find a rep for anybody, plus you gotta deal with shipping or some kind of rendezvous.
