Full Boost
Old Nov 5, 2008 | 07:33 PM
FLYNNBROS's Avatar
FLYNNBROS
Full Boost
Whats Up With Several Aftermarket Plug In Harness That Claim It Give You Full Boost??? Are They Worth It$45.00
Old Nov 5, 2008 | 07:48 PM
Pocket's Avatar
Pocket
The PCM has a boost limit that will cause it to go into a defueling mode. If you put a chip or tuner on, it's pretty easy to hit that overboost point. What boost foolers do is prevent the MAP sensor from ever seeing too much boost, and thus preventing an overboost situation with the PCM. Depending on your PCM, it will defuel when it sees either 22 psi or 24 psi.
A vast majority of people on this forum recommend this: Overboost Annihilator
I have it and it works great. I can hit higher boost levels and the truck just keeps pulling strong.
Old Nov 6, 2008 | 05:56 PM
FLYNNBROS's Avatar
FLYNNBROS
THEY SAY ITS OK FOR A STOCK APPLICATION...(NO TUNER,ETC) WHATS YOUR OPINION
Old Nov 6, 2008 | 06:22 PM
westpsd's Avatar
westpsd
It certainly won't hurt the truck, but stock progamming won't get you over 22 psi anyway so you will get no effect from it.
