Offroad & 4x4
Gaskets or silicone on trans spacer?
Old Oct 27, 2008 | 05:19 PM
T.McG's Avatar
T.McG
On my '94 F250, there is a spacer housing bolted between the transfer housing and the auto trans. Does this spacer require a gasket on each side or can it be siliconed?
Old Oct 27, 2008 | 05:43 PM
Ford150/428/dud's Avatar
Ford150/428/dud
Silicon it!!!!!!!!!!!!!
Old Oct 27, 2008 | 10:25 PM
straightsix4x4's Avatar
straightsix4x4
yep, I prefer ultra black, or ultra grey.
Old Sep 2, 2016 | 11:46 AM
KubotaOrange76's Avatar
KubotaOrange76
Its Comin Right for us!
gaskets for sure
Old Sep 6, 2016 | 09:44 PM
82F100SWB's Avatar
82F100SWB
I prefer using the gasket, you can actually get things apart later. Silicone can be a pain sometimes.
Some genius used the right stuff when he put the transmission in his Dodge... I could not get the 205 separated at the round pattern when I did the clutch...
Old Sep 9, 2016 | 03:56 PM
tjc transport's Avatar
tjc transport
i ain't rite
i use gaskets with a dab of sillycone to hold it in place during assembly
Old Sep 9, 2016 | 09:39 PM
mark a.'s Avatar
mark a.
If you are going to goop it get Honda bond #4 it is the "only" gasket maker that will resist trans fluid, hydraulic oil, gas, etc. The Permatex black or grey say right on the tube that it will not work, they are for engine oil.
Old Sep 16, 2016 | 05:34 AM
KubotaOrange76
good tech.....
stana1
6.7L Power Stroke Diesel
Oct 12, 2025 10:01 AM
mikey1968
23
Aug 14, 2017 08:20 AM
FordTruckfan89
Mar 2, 2017 11:05 AM
rjrandy96
Ford Truck Parts for Sale
Oct 2, 2016 02:35 PM
rjrandy96
Sep 25, 2016 09:14 AM
