I can't find an 07 programing guide, everything in my write-up is for an o4, however in the 08 .pdf under the 07 wiring it mentions Bank one, option one, you might try that. If that doesn't work call the help line that listed on the box 1-800-ford-key.
k thanx will do but have to see if i can return this bad module to the guy i got it from gonna hear from him tomorrow hopefully he will exchange it with no prob. i think that is half of my problem. LOL.
Any way to get the write up?
cannot seem to get a dropdown for the PM
I've got a module currently installed that has the Remote keyless entry, and the panic on the FOB and the Unit has the remote start connector .... need wiring diagrams and also it appears the tach inverter .... may already have it, but don't know what itlooks like....
If you need any assistance ...... I'll do the best I can. I just got finished isolating the Expedition liftgate cicuit from the remote start brain box..... I'm going to use it to roll up the windows when you press the lock and unlock button together. I just need to build a timing circuit to get it to work.
got mine installed all the advice i can give is hook up the correct wires to the correct wires. There are two black and white wires for door unlock and lock in the driverside doorpanel on a 2007. I found out the hard way.
