I can't find shift rail plugs anywhere locally and I need to get the tranny back in tonight. Any suggestions on a bandaid fix until I can find new plugs? Smear them with high-temp RTV?
Definitely remember to put sealant around the freeze plugs, they will leak if not. Sorry, don't remember the size. The only place that had the rubber ones was the dealer.
DO a search. You can use the flat steel freeze pulgs as a permanent fix. I just do not remember the size. some around 5/8"
I don't need to DO a search on the plugs, I know what I need. The fact is nobody local has the the Dorman or Dana plugs. Summit Racing stocks them but are out until 10/31 and I need to fix the truck now. I just went to the Ford dealer and ordered the factory plugs for $6.05 each and they'll be here tomorrow.
Yeah, everything is smooth as butter. I got the Perfection Brand slave and clutch kit at Advance because they had the best deal. The shift rail plugs came to the dealer the day after I ordered them. Used my Actron Brake Bleeder to bleed the system and everything is great. I really appreciate the help.
