Sponsored by: Auxito
Trailer light harness ??s
Old Oct 14, 2008 | 02:03 PM
dstryr's Avatar
dstryr
Hello, first post here...
I have an '01 supercrew with the factory tow package and when I first plug in my flat trailer using the round connector and hit the brakes the trailer brake lights will not come on. If I have the parking lights on the trailer lights go out when I hit the brakes. Same general thing when I use the 4 flat connector for another trailer.
BUT, after I am on the road for a short time, maybe a few miles, everything starts working and there are no more problems. I used to pull a trailer several times a year and don't believe I ever had this happen, but I haven't trailered much in the last 2-3 years. The first time this occured was a couple of years ago and then today.
Fuses are good- I swapped them out just to be sure with new ones and no change until I was on the road.
Has anyone experienced this or know if Ford has an issue with it?
Thanks,
Frank
Old Oct 14, 2008 | 02:40 PM
Ron W.'s Avatar
Ron W.
First guess, check and clean grounds, if needed fabricate a ground wire that runs from the truck to the trailer. Good luck.
Old Oct 15, 2008 | 05:23 PM
shorebird's Avatar
shorebird
Sure sounds like a grounding problem as Ron says.
Old Oct 15, 2008 | 07:17 PM
DirtStripHero's Avatar
DirtStripHero
welcome to the site!!!
Old Oct 16, 2008 | 08:03 AM
shorebird's Avatar
shorebird
Dstryr; Sorry but I forgot to say WELCOME to FTE.
Old Oct 16, 2008 | 09:32 PM
steve(ill)'s Avatar
steve(ill)
your getting your ground thru the ball hitch after thr rust wears off. get a good ground wire.
Old Oct 20, 2008 | 02:18 PM
dstryr's Avatar
dstryr
Thanks for all the replies and warm welcome. I'll add a ground wire and see what happens.
DavidCarr
All Things Towing
Mar 23, 2015 07:56 PM
DemonRace6
Jul 27, 2011 09:24 AM
freesoul
Sep 30, 2010 01:41 PM
hotrodracer
Dec 4, 2007 10:12 PM
97 RED PSD
All Things Towing
Mar 5, 2006 09:55 AM
