Trailer / 7-pin connector Question
Old Mar 1, 2015 | 08:43 PM
DavidCarr's Avatar
DavidCarr
I bought a used truck and then bought a used travel trailer. While moving the trailer today, I noticed I had no running lights on the trailer. When I hit the brakes, all the lights activated. When I used the right blinker, all the lights flashed like an emergency blinker. When I activated the left blinker, I got nothing.
I noticed some electrical tape on the 7pin connector from the trailer but haven't untaped it yet. Could it just be that the wires from the trailer are wired incorrectly or do I have a deeper problem?
F350 2001 4x2 Crew Cab. 26 foot Sierra travel trailer. 7 pin connector.
Thanks all for your help.
Old Mar 1, 2015 | 10:26 PM
r2millers's Avatar
r2millers
You have a very poor ground.
I would start by checking the 7 pin connector, cleaning both ends. I periodically spray wd 40 into the pin side and plug/unplug 5 or 6 times to get better contact.
If that doesn't work, trace the ground on both the truck and trailer, starting with the trailer side first.
Old Mar 2, 2015 | 07:10 AM
RV_Tech's Avatar
RV_Tech
Since you see tape where it is not suppose to be, start there. It is easy enough to undo the tape and see just what is going on there. You could have a combination of incorrect connections, poor connections including the ground as already stated, and even a burned out bulb. just take it a step at a time and you should be fine. It is unlikely anything serious is going on. just takes a little time.
Old Mar 23, 2015 | 05:49 PM
tawilson1152's Avatar
tawilson1152
Jumper cables between the truck and trailer will tell you if its a ground problem, which it is.
Old Mar 23, 2015 | 07:56 PM
RV_Tech's Avatar
RV_Tech
Have you had a chance to get back to this?
Steve
Jaybey
All Things Towing
16
Mar 8, 2020 03:30 PM
Casperman87
Mar 14, 2019 05:27 AM
Ex Factor
2009 - 2014 F150
Aug 6, 2015 12:41 PM
Rod Bensken
6.7L Power Stroke Diesel
Aug 6, 2013 12:41 PM
wedge88
Sep 24, 2012 07:42 PM
